LT1 Vette' air pump?
Old Dec 7, 2010 | 05:40 PM
89' RS/blue's Avatar
Car: 1989 RS Camaro
I have a 95' LT1 from a 9C1 caprice cop car i'm swapping into my 89 RS Camaro. I bought a LT1 corvette accessory mounting bracket to relocate the accessories. As far as I see this bracket only mounts the alternator, a/c compressor, power steering pump, belt tensioner assebly, & Idler pulley. However my LT1 came w/ a air pump....and I will need to have this hooked up to pass smog. I was just wondering where the air pump would mount up/ and/or if the air pump off the caprice will swap over. I do not see anywhere on the acc. bracket to mount the air pump, but california LT1 vette's had a air pump from the factory. I was just wondering where/how it mounts & if anyone else has had a similar issue.....??? Any help is greatly appreciated, thanks.
Old Dec 10, 2010 | 11:40 PM
Car: 1989 RS Camaro
Re: LT1 Vette' air pump?
Wow.......so no one has any clue huh...hmmmm. Oh well research time.
Old Dec 11, 2010 | 08:31 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I thought it was electric?
Old Dec 11, 2010 | 10:45 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
it was electric and i believe it was mounted to the frame rail similar to a 93 firebird/camaro lt1
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mcquigg
Aug 13, 2015 02:26 PM
