While the rear end is out, upgrade fuel pumps *again*?
Old Dec 23, 2010 | 09:47 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I'm hunting down a good rear for my car, been talking to Cam- about one of his 8.8's or maybe getting a 9". I'm hoping to have one in the next few weeks, so when I get my 10 bolt out of the car, I was thinking of possibly adding another Walbro 255 in the tank. I've already got one in there, but with the possibility of going turbo later down the road, figured it would be much easier to add one now then later. What would you guys do? Does the dual Walbro's sound like a solid plan or would you ditch the Walbro all together and get something totally different?
Old Dec 23, 2010 | 10:29 PM
Pocket's Avatar
Car: 91 Trans Am
Re: While the rear end is out, upgrade fuel pumps *again*?
Aeromotive is coming out with a 390lph intank pump January
http://www.ls1tech.com/forums/fuelin...tank-pump.html
Old Dec 23, 2010 | 10:37 PM
BlueZee28's Avatar
Hmmmm now that's an idea. I wonder how it would work if I just added one of those in my tank along with the Walbro 255. Think they'd behave together nicely? Or would it be ok with just that one Aeromotive pump if I end up with a turbo later down the road?
Old Dec 24, 2010 | 09:00 AM
Firebat's Avatar
I would upgrade gas tanks if you haven't already. I like my LS1 tank a lot better. The thirdgen tanks are known to leak at the filler neck especially if the tank was never replaced during the recall for 91-92 tanks. The LS1 tank has a "cup" where the fuel pump is held to supposedly to always keep fuel around the pump so when you go around a corner with a 1/4 tank of gas the engine won't cut out from fuel starvation. LS1 tanks are easier to install/remove since it sounds like you don't want to do the fuel door access modification.
Old Dec 24, 2010 | 10:54 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I bunged my tank with a -10AN line into an aeromotive A1000.
Cant go wrong that way, recommended hp upwards of 1200 capable on FI cars
Old Dec 24, 2010 | 10:55 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
If you dont like modding in that aspect, then do some Racetronix in tank pumps
Old Dec 24, 2010 | 11:08 AM
Pocket's Avatar
Car: 91 Trans Am
Filler neck issues are safety recalls and GM will have to honor them until all 91-92s are gone much like the seatbelt receivers
A dual pump setup in a LS1 tank requires cutting the bucket so any benefit it might have given will be long gone
A single aeromotive pump should be good for a ton of power. Id be going that route if I hadnt ordered a pair of 255's already
Old Dec 24, 2010 | 11:39 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
The new aeromotive pump looks promising. Might have to get me one for future mods
Old Dec 24, 2010 | 04:42 PM
BlueZee28's Avatar
I dont want an LS1 tank because I don't feel like messing with modding any wires or lines to make it work. My setup is awesome I just want to get a better pump for future use
I do have a dumped tank with an fittings but it would need to e cleaned out and I am not sure how having it would affect the fuel gauge, if any?
Old Dec 24, 2010 | 05:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
as long as the sender is still in the tank, the fuel gauge will not be an issue.
Old Dec 24, 2010 | 05:08 PM
Pocket's Avatar
Car: 91 Trans Am
Fuel gauge is on the sender which is replaceable
Old Dec 24, 2010 | 05:55 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Why couldn't you of posted this ad a day earlier...I just bought a Walbro 255
I would have definately prolonged my build for that aeromotive pump...time to go register on LS1tech....
Old Dec 24, 2010 | 06:29 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I will be using a A1000 for mine, but there are several guys on TTF using dual Walbos with no issues. Otherwise, a A1000 with a sumped stock tank in what i am going with for my 86 TA with a single turbo.
Old Dec 25, 2010 | 06:49 AM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
I have twin pumps going to go in.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
