LS6 intake questions
Old Jan 6, 2011 | 06:28 PM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
Picked up an LS6 intake without a throttle body and now I'm trying to figure out which TB I need. Can some of the guys who have used an LS6 intake chime in on which TB you used, did you use LS1 or LS6? I know the LS1 is 78mm and the LS6 is 85mm. My harness has a 5 wire provision for a MAF. Seems all LS6 TB are 5 wire and LS1 3 wire. Can the MAF be eliminated?
Which TB did you use and why?
Old Jan 6, 2011 | 07:05 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LS6 intake questions
LS1, LS6 both used the same 78mm TB
Trucks use a 5 wire 85mm MAF. Its the same 3 wire MAF as the cars, but incorporates the IAT into the mix for a highly accurate (and larger opening) sensor. LT1/LS1/CPI trucks all use the 75mm 3 wire MAF
The MAF can be deleted with a speed density tune. If you dont have a good reason to run SD, I wouldnt
Old Jan 6, 2011 | 07:09 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
You should just be able to use your old throttle body and maf unless you want to upgrade those as well. If you are planning to get your computer tuned i would use the 85mm maf.
Old Jan 6, 2011 | 07:33 PM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
I would but the truck TB is DBW and doesn't come with a MAF or I would have reused it
Old Jan 6, 2011 | 07:35 PM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
So since I'm starting with a truck harness and based on the added accuracy of the IAT reading and larger opening, I should look for the truck MAF? This will bolt in place with either TB?
Old Jan 6, 2011 | 08:23 PM
Pocket's Avatar
Car: 91 Trans Am
You have to fab an intake tract so using the 4" OD 5 wire MAF vs the 3.5" OD 3 wire MAF is up to you
Old Jan 6, 2011 | 08:38 PM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
Helpful as always. Thanks!
Old Jan 16, 2011 | 10:16 AM
JSACRA's Avatar
Car: 89 IROC-Z
Engine: 6.2 LS3
Transmission: MN12 T56 GTO
Doesn't hawks carry the 5 to 3 wire converstion harness or visa versa
Old Jan 16, 2011 | 10:33 AM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
It's possible that they do, but it's not my first choice to buy stuff from. Do they have what you need? Yes...do they have what you need at a reasonable price? No.
I've got the MAF issue handled and will just use the 5 wire and make it work
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
