LT1 from a Caprice?
Old Jan 19, 2011 | 01:42 AM
native1031's Avatar
LT1 from a Caprice?
So im trying to get a hold of a complete lt1 swap and was wondering what would be the difference compared to getting a complete swap from a camaro if any?
Old Jan 19, 2011 | 03:45 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: LT1 from a Caprice?
4th gen F-body has AL heads,better cam and bigger TB. The heads flow about the same. Some argue that the iron heads flow better.The accessories from the Caprice also stick out a little bit but not enough to make a difference. Everything else is the same.
You also have need to change the tailshaft of the tranny if you plan to use it.
FYI I am selling a running car with an LT1(94 Fleetwood)
Old Jan 19, 2011 | 01:27 PM
native1031's Avatar
I just noticed I didnt do a good job at specifications, sorry.
I wanted to compare lets say a 94 caprice LT1 to a 94 camaro LT1
Where are you located?
Old Jan 19, 2011 | 01:30 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
A F body Lt1 has aluminum heads so it weighs roughly 50 lbs less. I believe it has a more aggressive cam as well. From what I hear the cast heads flow the slightest bit better then the aluminum though.
Old Jan 19, 2011 | 02:08 PM
andy74's Avatar
Car: 1988 gta carbed 383
Engine: small block 4bbl
Axle/Gears: 3.27 g80
the cam profile in a impala/caprice builds a little more low end torque,and as stated they b bodies had iron heads as opposed to aluminum-if its a reasonable price id pick it up,am considering the same swap on one of my cars too
Old Jan 19, 2011 | 02:20 PM
native1031's Avatar
Thanks, however in the end the money will make my decision.
Old Jan 19, 2011 | 09:19 PM
Pocket's Avatar
Car: 91 Trans Am
Same TB was used on B, F and Y LT1's
If the B-body LT1 is over $300, pass
Old Jan 19, 2011 | 09:23 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
What's the difference in them?
Old Jan 20, 2011 | 06:01 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
im in Ontario, Canada
Old Jan 21, 2011 | 07:31 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Make sure it is the 350 LT1 and not the baby 4.8 LT1.
Old Jan 21, 2011 | 07:48 AM
andy74's Avatar
actually the small lt1 type engine is a 4.3 liter,its called a l99,just so you know!
Old Jan 21, 2011 | 08:51 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Doh, thanks for the correction. Brain failure.
Old Jan 21, 2011 | 11:05 AM
andy74's Avatar
it happens to me all the time!no worries
F.I. 57 Belair
Aug 23, 2021 01:09 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
