LSX Swap Interchangeable / Swappable bolts
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
So i really want to establish a good thread on what bolts from say a 5.3 / 6.0 etc can be swapped around based on an LS1 style build (ex. making a 5.3 into an LS1 when you start with a complete 5.3 engine with all accessories on it like myself). As ive started getting closer to buying a T56 to finish buyin all my swap parts so im ready to do this swap im now looking for bolts/hardware and my first purchase was LS1 intake bolts. You'd think these are cheap but do not be mistaken, from a dealer they are $55 for a set of OEM style and for $50 you can get a set of ARP's so if a few sets of bolts might start adding up quite a bit, id like to re-use as many of the 5.3's accessory bolts as i can. I bought a used set for now from LS1 tech for $27. MY next few searches will be Waterpump bolts, pan bolts etc... are they the same between a 5.3 and LS1, im thinking they are... Any input is GREATLY appreciated.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: LSX Swap Interchangeable / Swappable bolts
oil pan and water pump bolts are the same. Several of the large bracket bolts that hold the PS and alternator can be used for the f-body as well.
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
Hello,
I am doing a ls1-t56 swap on my car too. I don't have any of the accessory bolts. Does anyone have a set for sale? Or maybe know the specs to by the bolts from a hardware store. Over here in the Dallas, TX area Ace True Value has almost every bolt you can think of. I would rather have the OEM bolts, But sometimes aftermarket is better anyway.
Or the part numbers for the bolts from the Dealer?
Thanks for your help
Robbie
Robbie
I think the list would be shorter with that bolts DONT interchange freely
Only ones I can think of are the truck intake vs car intake because of length. Mcmaster carr can order any bolt size imaginable cheaper than dealers/hardware stores
Use this site to find the proper length/thread
http://www.compnine.com/
ambainb
Apr 25, 2016 09:21 PM
