TKO With 5.3
Old Feb 25, 2011 | 07:43 PM
gadocbar's Avatar
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
TKO With 5.3
Has anyone us a tko behind the ls and if so what adapter or parts did you use
Old Feb 25, 2011 | 10:31 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: TKO With 5.3
there is a bell housing for this. McCleod sells it. I havent used it so I dont know what little things are needed. or if it means a longer DS. It would be one of the better trans to use though
Old Feb 26, 2011 | 09:08 AM
gadocbar's Avatar
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
Re: TKO With 5.3
Thanks for the info
Old Feb 26, 2011 | 03:01 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: TKO With 5.3
Why unless you already have it? The t56 is a better choice IMO. Strong as he'll and a proven performer for less money
Old Feb 27, 2011 | 06:17 PM
Engine: ls1, LB9
Re: TKO With 5.3
honestly for the money people want for t56's now days its not. you can get a new tko500 for almost the same or even a tko600 for a few hundred more. which is even stronger yet. the 500 is rated the same as the t56 but based on its internals I think its a little under rated.
I would go with any of the three.
Old Feb 28, 2011 | 05:31 AM
1badeagle's Avatar
Engine: 370 LSX
Re: TKO With 5.3
Just browsing ls1 tech got me a t56/bellhousing/clutch/pressure plate/flywheel/slave out of a 43k car for 850$ shipped.
Old Feb 28, 2011 | 02:27 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
Re: TKO With 5.3
Where? I'll buy it right now!
Old Feb 28, 2011 | 05:39 PM
Engine: ls1, LB9
Re: TKO With 5.3
that might be so but the average price is much much higher.
I can go all day with how cheap you CAN find some but that's not the average price by far!
the point here is the TKO is not a bad trans and in many cases can be found at similar prices. so to tell some one they shouldn't is a little narrow minded.
Old Feb 28, 2011 | 08:05 PM
1badeagle's Avatar
Engine: 370 LSX
Re: TKO With 5.3
I already bought it.
Not so narrow minded. You can have a good factory gm tranny complete setup for 900$ if you shop and you get a extra gear which is nice when gas is 3.50$
Old Mar 1, 2011 | 08:14 PM
Engine: ls1, LB9
Re: TKO With 5.3
give it up guy! you came into a thread to bash what he wanted to do. admit it your a troll. do a search if your so prod and see I got my last t56 for under 300.00 with everything. and the last tko I had in my hands was 500.00 I wasnt going to talk prices like you seem so happy to do. just move on and let threads that are here to inform to just that
Old Mar 1, 2011 | 08:19 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: TKO With 5.3
If you re-read the thread he didn't talk cost until after you talked about t56's being over priced.
Old Mar 1, 2011 | 09:59 PM
1badeagle's Avatar
Engine: 370 LSX
Re: TKO With 5.3
I'm not bashing just suggesting a 6 speed. I will call you a liar on your 300$ complete setup t56. Must have been a bare case or a core.
Last edited by 1badeagle; Mar 1, 2011 at 11:11 PM. Reason: Not gonna stoop to this dicks level and name call.
Old Mar 1, 2011 | 10:11 PM
1badeagle's Avatar
Engine: 370 LSX
Re: TKO With 5.3
Another stand point to look at is, how many new cars are using 5 speed trannys?
ZZ3Astro
Aug 13, 2019 12:57 AM
deracer
Apr 11, 2016 12:04 AM
customblackbird
Oct 1, 2015 04:30 PM
Amillionoh7
Sep 11, 2015 11:36 AM
jharrison5
Aug 19, 2015 05:53 PM
