ls2 timing chain swap ls6
Old Mar 11, 2011 | 09:07 PM
chris lo's Avatar
Car: 92 z28 vert
Engine: ls6
Transmission: t56 magnum
Axle/Gears: moser 9 inch 4.11
i am getting ready to put a ms4 cam in my ls6 and i have read on here some where to switch the timing chain and gears to a ls2 setup is it true that the ls2 chain is stronger if so what year ls2 or are all ls2 timing sets the same thanks
Old Mar 11, 2011 | 09:48 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: ls2 timing chain swap ls6
Yep. Join ls1tech.com and contact yank. You can get a new ls2 timing set for 68$ shipped.
Old Mar 11, 2011 | 10:18 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
The same thing I did. But you just want the chain, not the gears. The GM part number for the LS2 chain has become the stock replacement for the LS1. I just recently installed one myself and its much beefier then stock. It will cost you $42 shipped.
Old Mar 11, 2011 | 10:20 PM
1badeagle's Avatar
Engine: 370 LSX
I bought gears for peace of mind since my motor had a few miles on it.
Old Mar 11, 2011 | 10:37 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i too grabbed one since the motor had high miles and it was cheap insurance.
Old Mar 12, 2011 | 08:25 PM
Pocket's Avatar
Car: 91 Trans Am
Also got one for my 6.0
Old Mar 12, 2011 | 08:40 PM
chris lo's Avatar
Car: 92 z28 vert
Engine: ls6
So will the ls2 gears work on the ls6 to I don't want to replace just the chain
Old Mar 12, 2011 | 09:17 PM
1badeagle's Avatar
Engine: 370 LSX
Your good to go. It's all swappable.
Old Mar 12, 2011 | 09:22 PM
chris lo's Avatar
Car: 92 z28 vert
Engine: ls6
ok thanks
Old Mar 12, 2011 | 09:27 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
While your in there try and track down a chain damper if your up to the challenge. The LS2 chain will always have a hair of slack without it. Some blocks were drilled for the damper and some were not, but finding the 'tan' damper is tough to do because they were discontinued.
The tan damper would be bolt in if your block was pre drilled. But if it wasn't you could always drill and tap for the black one.
Old Mar 13, 2011 | 10:43 AM
chris lo's Avatar
Car: 92 z28 vert
Engine: ls6
my block already has the chain damper on it i am going to jegs to pick up a set in a little bit thanks
Vintageracer
Jan 10, 2020 05:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Thirim
Aug 13, 2015 03:09 PM
