Engine mount brackets, just want to make sure
Old Mar 25, 2011 | 05:40 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
I searched and cant find a definitive answer... Im pulling my V6 and swapping in an LT1. Just so I'm sure, I have to use 3rd gen engine mount brackets (the bracket that bolts to the block) from a V8 thirdgen, correct?
Old Mar 25, 2011 | 07:07 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Engine mount brackets, just want to make sure
correct
Old Mar 28, 2011 | 12:42 PM
Firebat's Avatar
I agree, correct, but may have to modify them.
-If using the LT1 f-body a/c with stock LT1 f-body (or b-body about the same) bracket then you must grind down the passenser side "clam shell" (engine mount bracket) until you have enough clearance for the a/c compressor. Motor mounts and engine brackets go in the SBC V8 locations and must be for a V8 thirdgen. Also K-member has to be messaged or notched for a/c compressor clearance.
-If not using a/c with f-body(b-body) bracket and using the GM a/c delete pulley (or even better the Bowers LT1 a/c delete pulley) then both the K-member and motor mount bracket will not need modifications.
Old Mar 28, 2011 | 05:41 PM
drdave88's Avatar
Engine: 6.0L
No A/C will be going on here so it looks like I'm all set. Thanks for the info guys.
jhawkeye
May 25, 2022 06:33 PM
Terrell351
Jun 13, 2021 01:13 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
