Tach
Old Mar 27, 2011 | 05:14 PM
gbrett's Avatar
Tach
I'm finishing up a LS1 swap on 1991 GTA and I'm having trouble finding the wire to hook up my tach output to. I also am not sure if my programer changed my tach signal to a v8 signal so do I have any other options other than having my ecm redone.
Old Mar 27, 2011 | 10:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Connector C105 (also the #10 wire from the Red PCM connector), white.
http://www.team3rdgen.com/modules/3r...s/99wiring.jpg
Or, did you mean the chassis wire?
C100, D6, also white.
If the PCM wasn't reset, your only choice is an aftermarket tach set on 4 cyl.
Old Mar 28, 2011 | 12:45 AM
daddy33's Avatar
Car: '85 Camaro
Re: Tach
^^^ good info to know
Old Mar 28, 2011 | 11:07 AM
gbrett's Avatar
Re: Tach
what about using one of these http://www.dakotadigital.com/index.c...rod/prd127.htm
Old Mar 28, 2011 | 04:40 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Tach
You can use the box but if the tuner forgot something make him fix his mistake
Beware birds usually require the booster wire to get the tach working. Wrong tach value means tune issue, no tach means booster needed
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
