So I'm getting the GTA out to drive
Old Apr 8, 2011 | 08:31 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
since I blew a head gasket in the '98 the other night, so it's going to be down for a while. I figured "I need to change the oil since the car has sat since '08". I pull the oil plug and it looks like 90w gear oil coming out, actually thicker than that. This was Castrol Syntec oil that was in the car and it looked like molassas coming out. Has anyone seen this happen before with synthetic oil? This motor has less than 5k miles on it since I rebuilt it. My uncle who used to work for Cummings diesel and a state DOT mechanic for years gave me some suggestions to get it thinned out enough to get the oil out so wish me luck with it.
Now I have to go buy some regular oil to put in it before I throw the Royal Purple in it
Old Apr 9, 2011 | 11:52 AM
Klortho's Avatar
Car: 1987 GTA
Re: So I'm getting the GTA out to drive
Well, looks like the trick worked. Let the kerosene sit overnight, pulled the drain plug this morning and let it sit while my daughter had softball practice. Came back, put the plug in, the oil filter on filled it up with 5 quarts of standard oil and she's holding 40psi at idle. Going to drive it a week, change the oil again, drive it another week then put the royal purple in it and call it good.
Old Apr 11, 2011 | 09:57 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Hmm I run the German Castrol too and I have noticed that its VERY thick every spring after storage. I keep in the garage at home and drive it to the shop for the spring freshen up/oil change etc. I had a PCV delete with a filter on there so I chalked it up to condensation absorbing over the winter but?
Old Apr 11, 2011 | 12:01 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Castrol regular oil is great, the synthetic not so much, Mobil 1 is the way to go.
Old Apr 11, 2011 | 12:09 PM
Klortho's Avatar
Car: 1987 GTA
Well for the cost difference between Mobil 1 and Royal Purple I think i'll stick with RP
Old Apr 11, 2011 | 11:57 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Royal purple breaks down too damn fast, no thanks.
Old Apr 12, 2011 | 12:09 AM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Castrol GTX all the way.
Old Apr 12, 2011 | 12:58 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I use Castrol GTX also, but I have to ask this question because it is in all the forums.
What does GTA stand for? I looked on line and all I Could find was grand theft auto..LOL I know it will be something I should know but Iam tired of guessing...
Old Apr 12, 2011 | 01:01 AM
Engine: MPFI
Ok its a really hot car..lol
https://www.thirdgen.org/tech/images...AMsting_sm.jpg
Old Apr 12, 2011 | 01:04 AM
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Gran Turismo Americano.
lee01
Apr 9, 2016 01:56 PM
The_Phoenix
Feb 4, 2016 07:10 AM
gta90
Sep 15, 2015 04:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
gta power
Aug 13, 2015 06:15 AM
