Brake fluid leaking inside car from Tick MC??
Old Apr 24, 2011 | 07:34 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I was buttoning up under my dash today and noticed the black rubber cover on the master cylinder rod was wet from brake fluid. I pushed it in a little and it oozed out more fluid. What the heck is up with that? Is that normal, and has anyone experienced this? I have had clutch issues all last year and was attributing it to the fluid deteriorating from not having the rubber gasket inside the reservoir... I wiped off the rod and rubber cover inside the car before I started bleeding the clutch and didn't see any more come out. This seems strange to me.
Does anyone know if when you spin the rod if it can come disconnected from the mechanism inside the master cylinder? It's a Tick mc...
Old Apr 25, 2011 | 02:41 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: Brake fluid leaking inside car from Tick MC??
Sounds like the pushrod seal is deteriorated. Are you sure you are using the correct fluid for the master cyl? Some types of fluids are bad for certain tyles of seals and will cause them to dissolve.
Old Apr 25, 2011 | 10:46 AM
BlueZee28's Avatar
I'm just using regular ol' Dot 3 or Dot 4 brake fluid from the local parts store, nothing fancy.
I got off the phone with Tick and they said if I send it to them they'll send me a brand new one. This kind of sucks because I'm taking the car to a show out of town this coming weekend. Guess I'll be working on removing it as soon as I get home.
I did check to make sure the rod was going into the MC straight and not crooked, since it's a swapped car and was originally an auto, so I didn't have the mounting holes already there. I had to drill them out myself, and from looking at it, it looks straight to me.
Old Apr 25, 2011 | 06:42 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Dude, that sucks. I feel the pain, its definately not normal tho. Mine doesnt leak and I never heard anyone having problems with a Tick MC. Keep us posted.
Old Apr 25, 2011 | 06:55 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Originally Posted by Spike-Z
Dude, that sucks. I feel the pain, its definately not normal tho. Mine doesn't leak and I never heard anyone having problems with a Tick MC. Keep us posted.
there has been a few on ls1tech but I think most if not all were said to have put vacuum or pressure (cant remember) on the system during bleeding
Old Apr 26, 2011 | 07:52 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
So far i haven't had issue with my tick MC... been running it since my original LS3 conversion in '09 without trouble
I didn't use any bleed on mine other than traditional pedal (ie no vacuum, etc)
Old Apr 26, 2011 | 08:28 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
I just bought a tick mc myself and about to start converting from auto to 6spd,do any of you guys have good tips for installing the tick compared to the stock fbody master?Im going to be using 4th gen pedals aswell.Im looking at the master and I dont quite understand how this thing is supposed to mount to the firewall with and angled face...maybe its just me since Im still gathering parts.
Attached Thumbnails Brake fluid leaking inside car from Tick MC??-img-20110426-00005.jpg
Old Apr 26, 2011 | 09:02 PM
BlueZee28's Avatar
At least the removal was painless. I somehow managed to get it out of the car without removing or touching anything else including the booster. I took the rod off from inside, took the hydro line off at the AN fitting, and slid it out between the fender and brake lines.
It should be at Tick tomorrow and they said their turnaround is same day, might have it installed and running by this weekend so I can test it out. I'll update my findings.
I took the boot off the rod when I removed the mc and the thing was SOAKED! Definitely not normal...
Old Apr 26, 2011 | 09:15 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Glad to hear that Ticks service is a quick turnaround.Hopefully thats the only issues and will be up and running within a day.
Would you be able to take pics of how your tick was setup on your car.What did you use for clutch reservoir and bracket.Thanks a bunch.
Old Apr 26, 2011 | 09:33 PM
BlueZee28's Avatar
Yea I can post pictures after I get it back in. I am using a stock 3rd gen reservoir and bracket. It mounts to the driver side bolt holding the brake master cylinder to the booster.
Old Apr 26, 2011 | 09:38 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
I still need to get a reservoir and make a line to the master.Can I use any reservoir as long as it holds a large amount of brake fluid?The use rubber brake line to the master and call it a day?Finding thirden manual parts here arent easy..4th gens are always stripped beyond use for my swap
Old May 1, 2011 | 02:09 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Any updates Blue?
Hope you were able to get the car up and running on time?
Old May 2, 2011 | 12:33 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
These are Tilton master cylinders we're talking about here... Metal bodied racing units more or less haha. They should be able to withstand slight angles and different fluids.
I dont think mine seeped anything. Ill have to check it next time Im around the car...its been sitting, so if the seals were going to go bad, now would be the time.
I did hit the clutch a few times last time I was with the car, and it felt fine. Stiff for the first push, then felt great.
Let us know how you make out!
J.
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Kaweh
Aug 9, 2015 02:54 PM
mustangman65_79
Aug 7, 2015 09:55 PM
Leggman1
Aug 6, 2015 04:15 AM
