LSx trans mount question
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
I’m wondering if there is a specific trans mount I need in able to use the Spohn LS1 swap crossmember with my 2000 4L60e. I have two mounts and neither are quite right.
The mount I originally had on my 700r4 – the bolt on the bottom is not long enough.
The mount that came with the 4L60e – the bolt is long enough, but the diameter is too large.
I guess I could enlarge the holes on the crossmember but there isn’t that much material to begin with. Any suggestions?
Re: LSx trans mount question
Its designed around a poly trans mount that uses bolts inside, not studs like the stock rubber
Mod it or run a different mount, your call. Any will work
