alt to motor mount issue
Old May 9, 2011 | 11:51 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
I drilled and tapped the hole for the alt mounting bracket and whe I went to mount the alt the plastic shield on the back of it is hitting the driverside clamshell. I'm going to swap it out tonight with another clamshell that I have that looks lell "bent" I guess you could say and see if it helps. Just wondering if anyone else had a similar issue. I'm using the 1in setback plates.
Old May 10, 2011 | 12:08 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: alt to motor mount issue
was able to get mine installed, just a little tight, which alt are you using - fbody or truck?
Old May 10, 2011 | 03:07 AM
Screamin86's Avatar
fbody. i think the clamshell i used on that side is a little mushroomed out like when it was made its phyisicly wider than the one i used on the pass side. i went out to work on it some tonight but the wife pilled of more stuff in the garage so i spent more time moving things than working. ill swap it out in the next day or so and see what happens. ill try to get some pictures of it.
Frozer!!!
Jan 19, 2024 04:55 PM
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
