need a little help w/heater hoses, LT1 swap using LT1 radiator
Old May 25, 2011 | 08:40 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Like the title says, doing the LT1 swap, using the LT1 radiator.
I have the LT1 radiator hoses all hooked up. What im confused on, are the heater hose routing, and the HVAC 3 hose control.. there is 1 port on the LT1 water pump passenger side and is pointed up, what hooks up to that? also th passenger frame rail at the bottom that used to go to the radiator.
anyone have a diagram on how they hooked their up using this set up?
Old May 26, 2011 | 05:17 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: need a little help w/heater hoses, LT1 swap using LT1 radiator
I'll look under my hood today when I get home from work and figure out how I did it.
be damned if I can remember now though......
Old May 26, 2011 | 10:46 AM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
awesome, thank you
Old May 26, 2011 | 12:29 PM
Firebat's Avatar
The heater core has 2 ports that each use a different sizes of heater hose. After you cap off the far bottom drivers side port on the LT1 water pump, there will only be 2 ports left on the water pump and I believe they are each a different size. Match the heater port size to the water pump size. Buy a good length of each size of hose and route it either on top of the engine or along the passenger side on the bottom by the frame rail. For the vacuum controlled heater valve, I am not sure how they one with 3 ports is hooked up (but could find out by looking at my non-LT1 firebird), the one with 2 ports is just connected inline with one of the heaters hoses. Some people think the heater valve is optional, I've never looked into it much so I don't know if it's worth keeping or not.
Old May 26, 2011 | 04:28 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
thanks for the info, but it still doesnt solve the issue.
there is still the hardline port on the passenger frame rail, it has 2 ports actually.. one that goes up to the 3 port valve .. and the straight one that went to the radiator..
Old May 28, 2011 | 09:09 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
bump
Old May 29, 2011 | 05:08 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
damn, forgot all about this...... will check tomorrow after I get home from work......
Old May 31, 2011 | 01:44 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
and you forgot again
also what about vacuum lines and the HVAC check valve?
Old May 31, 2011 | 02:53 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Ok, here's what I did. Mine didn't have the 3 way heater control valve when I got the car, or the hardlines so I ran the top heater hose to the top connector on the passenger side of the water pump that is turned up, the bottom hose going into the heater core to the bottom connector that was turned down.
Driver side lower connector on the waterpump goes to the nipple on the radiator at the bottom driver side (only if you have removed the oil cooler)
Attached Thumbnails need a little help w/heater hoses, LT1 swap using LT1 radiator-2005_0419image0151.jpg   need a little help w/heater hoses, LT1 swap using LT1 radiator-2005_0419image0154.jpg
Old May 31, 2011 | 07:50 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
yep, I got busy... again
so its pretty straight forward.
Take the hose from the top of the waterpump, run that to the diverter, that splits it to the heater core, and the pipe on the frame rail.
the return line that used to go to the radiator, goes back to the bottom of the waterpump. Thats it.
Vacuum, I teed into the rear of the intake manifold, put the check ball in place and ran the accessories off of that.
good luck with the rest of your swap
Old Jun 2, 2011 | 11:49 AM
newZman's Avatar
Car: 99 Tahoe, 98 Buick, 84 Camaro
Engine: 350, 2800, none at the moment
This is a great picture... I see you got your Raid out for them pesky elctrical bugs. I'm not sure that will work. Sorry I couldn't help that one.
Originally Posted by Klortho
Old Mar 21, 2012 | 01:45 PM
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
I dont if you can help doing lt1 swap into a 86 Iroc Z I am using the stock camaro radiator the heater hoses go the left goes to the radiator the right go to water pump but on the Lt1 shouldn't both heater hoses go to the water pump do they sell a cap to plug the radiator where the stock heater goes ?thanks
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
