Pulled my ls1/t56 today from doner 2001 Trans Am. I got the ecm and wireing from ecm to the engine. My question is do I need the wireing from the other side of the engine bay that goes to the two fuse blockes that sit behind the driver side head light on the 2001 T/A? Thanks for your help.
If your going to use the 4 gen dash with the gauges You can cut the abs and bcm out.
if you've got the complete pcm harness, you should be ok. but grab everything you can - better to have too much stuff than not enough!
five7kid
close
I got the fuse/relay boxes with the 2nd drop-out (LS1/4L60E). I cleaned up the harnesses of things I wouldn't need and mounted them behind the left headlight. You can pick them out below the air filter.
I used an eBay swap fuse/relay box in the LS1/T56 swap. Although they take up more space, the factory boxes turned out to be easier to wire up. I agree with Dan - grab all you can.
five7kid
close
This is what it looked like as pulled from the donor car:
And after I removed the unneeded wires from the box harness (sorry, didn't get of shot of them wrapped & cleaned up - I was doing this in a hurry):
If it was me, I would get pocket to make a custom 3rd gen ls1 harness. I've seen his work, and it's great
I agree with mark, pocket did my harness and its plug and play when u get it. he does good work
Quote:
He is referring to my 92 z28 and Pocket made it so easy plug and play! I will be buying another one for my 91 z28 vert swapOriginally Posted by 58mark
If it was me, I would get pocket to make a custom 3rd gen ls1 harness. I've seen his work, and it's great And Pocket is in your area........
Thanks guys!!!! I need to go back and get some wireing. I thought i could use that side of my wireing from my car. Who is pocket?
Hello,
He is a member here, and i am sure he will chime in soon!
how much does it cost to get a harness converted?
pocket doesn't convert them, he builds a new one from scratch
Not sure on the cost
No, I convert used harnesses to plug into 3rd gen engine bays. No new wiring from me
turbota82, shoot me a PM
AH. didn't know that. looked so clean I assumed it was new
