lsx help
Old Jun 12, 2011 | 10:28 PM
jfroh1992's Avatar
Car: 91 RS, 93 k1500
Transmission: T5, NV3500
Axle/Gears: stock
lsx help
i am picking up a lq4 6 liter tommorow that will eventually end up in my 86 IROC but i am new to the lsxs so im not completly sure on what all interchanges between them.
there is someone locally selling a ls6 z06 clutch and im not sure if it will work since the vettes are transaxle.
also it has heads from a 5.3 on it im not sure of casting numbers and am wondering if im better off with those or ls1 heads.
if anyone can help me out please let me know
Old Jun 12, 2011 | 11:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: lsx help
What year is the engine? The first 2 years had a different length of flywheel mount on the crank, so the LS type clutches won't work on them. If one of the later ones, the LS6 flywheel & clutch will work.
LS6 or LQ4/9 heads would be better than the 5.3 heads.
Old Jun 12, 2011 | 11:31 PM
jfroh1992's Avatar
Axle/Gears: stock
Re: lsx help
its a 2001
Old Jun 12, 2011 | 11:55 PM
Guest
Guest
Posts: n/a
Re: lsx help
Unless those 5.3 heads have been CNC ported by one of the big-name, nationally-known porting shops.
Old Jun 13, 2011 | 12:15 AM
five7kid's Avatar
Originally Posted by jfroh1992
its a 2001
I believe that has the long crank output flange then. An LS1 crank will swap in if you want to go that route.
I guess I missed the part where he said they were 5.3 heads CNC ported by one of the big-name, nationally-known porting shops...
Old Jun 13, 2011 | 12:23 AM
jfroh1992's Avatar
Axle/Gears: stock
Re: lsx help
Do you know what the difference between the two is just so I can be sure
jfroh1992's Avatar
Axle/Gears: stock
Re: lsx help
And no they are just stock heads from a 5.3
Old Jun 13, 2011 | 09:08 AM
Guest
Guest
Posts: n/a
Re: lsx help
I did specify: "unless".
IDK if they all stamp their logos into both ends of every head, or what, but it is a popular way to get flow with compression. Better than milled but un-ported 243s / 799s.
Old Jun 13, 2011 | 09:25 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: lsx help
5.3 heads dont flow as amuch due to smaller valve sizes compared to the 317 castings often found on truck motors i believe. 799/243 heads are very similar but have smaller combustion chambers than the 317's for more compression. Those are often found on LS2 motors. If you can score a set of those, go for it. Even 317's make a nice head once milled down abit for more compression.
Old Jun 13, 2011 | 04:15 PM
Pocket's Avatar
Car: 91 Trans Am
Re: lsx help
Look at the crank flange under the flexplate. If the flange is approx flush with the RMS, you can use whatever clutch you want. If the flange sticks out approx 1/2" the crank needs to be changed
Old Jun 13, 2011 | 09:49 PM
jfroh1992's Avatar
Axle/Gears: stock
Re: lsx help
Just finished unloading the motor. The back of the crank is almost flush with the back of the block would that mean id be able to use a ls1 clutch/flywheel
Old Jun 13, 2011 | 10:38 PM
jfroh1992's Avatar
Axle/Gears: stock
Re: lsx help
didnt read this before i posted.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Buggy Disaster
Sep 22, 2015 01:15 PM
