rocker brand prefs
Old Jul 11, 2011 | 04:22 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
rocker brand prefs
I need to return the set of rockers I purchased from summit, and I need to find a differant set. These are going onto an LT1, fully roller, 1.5 ratio, 3/8 stud, and NSA. what are some of your preferences? I'm looking at Scorpion and Harland Sharp aluminums right now.
Old Jul 12, 2011 | 12:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Have you looked at the Comp Ultra Pro Magnums?
Old Jul 12, 2011 | 12:02 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: rocker brand prefs
aluminum is no good for a daily driver
Old Jul 12, 2011 | 01:53 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i have used the comp pro magnums, (non-ultras) with good results.
Old Jul 12, 2011 | 04:44 PM
Car: 86 Camaro Z28
then I ought to look at the steel roller rockers. It looks like 1601-16 is the part I need to get then. thank you for the advise guys, I appreciate it.
Old Jul 12, 2011 | 05:17 PM
five7kid's Avatar
I think you'll like them.
Old Jul 12, 2011 | 06:29 PM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
Any particular reasons you say this?
M
Old Jul 12, 2011 | 08:33 PM
mw66nova's Avatar
Engine: 7.0L
M
material fatigue vs a steel rocker makes it less reliable. doesn't mean it won't work, just not as reliable. i have a set of crane blue racer aluminum roller rockers in a street motor with over 80k miles on them so far, but with the availability of rockers like the comp pro-magnum line, that are 15% lighter at the valve than aluminum rockers, and are far more reliable, why wouldn't you want to use them?
Old Jul 13, 2011 | 01:02 AM
xpndbl3's Avatar
Car: 1984 Z28
aluminum can fatigue and crack and sometimes the rocker body falls in sideways and can hang the opposite valve up and take out a motor.
Old Jul 13, 2011 | 07:21 AM
mwfrels's Avatar
Car: '86 Z28
Transmission: WC T5
I understand the material fatigue issue but I would go with the feeling that it is only a real issue with a high lift, high spring force, higher rev motor built for serious performance. My build is going to be a non-track DD. The only issue I see is possibly high mileage therefore high-cycle fatigue. I wanted Comp Pro-Magnums because they are steel but I need 1.7 ratio rockers 'cause I am going with an LS2. The aluminum Ultra Golds from what I have researched are all Comp can provide me with.
M
Old Jul 13, 2011 | 07:48 AM
mw66nova's Avatar
Engine: 7.0L
if you're going with an lsx engine with DD in mind and you want reliability, go with a comp trunion upgrade on the stock rockers and be done with it. i have a moderate camshaft, and the engine sees 7000rpm shift points, running upgraded stock rockers with no issues. the benefit of an aftermarket rocker on an lsx engine isn't realized till you need an adjustable valvetrain like what would be associated with a solid roller camshaft.
Old Jul 13, 2011 | 06:58 PM
mwfrels's Avatar
Car: '86 Z28
Transmission: WC T5
The main feature of roller rockers I want for the engine is the roller tip. I want to minimize if not eliminate the side load on the valve stem as the rocker swings through its arc opening & closing the valves. Current 350 in my car has the roller tip only Comp Magnums. Last year at ~60k miles I checked stem play on a couple of valves and it was in the bottom end of the range of allowable tolerance on each. I like to take the mileage on my engines well into several 100K before having to rebuild or replace. My theory whether valid or not is that less stem slop helps for longer valve seat geometry life and therefore better sealing for longer.
M
Old Jul 13, 2011 | 10:51 PM
xpndbl3's Avatar
Car: 1984 Z28
so original post is talking about an lt1, now you're talking about an ls2 motor....which is it? And I've seen several ls based motors into the 250k+ range still running stock rockers, which are the best choice for a daily driver, no reason to upgrade like older gen 1 motors.
Old Jul 14, 2011 | 12:11 AM
five7kid's Avatar
I know a 412 7500 RPM Paxton charged street driving raced regularly LSx that used stock rockers, didn't even have the trunion upgrade (forget the lift, but that guy doesn't do anything small).
Okay, let's keep the posts on-topic to the original LT1 question. The ones wanting to discuss LSx will have to go get a room...
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
92firebirdguy
Sep 10, 2015 10:33 PM
