LSX T56 Hydraulic Line question
Old Jul 18, 2011 | 12:01 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
So i searched around a bit and didnt find an answer, possibly i overlooked it but heres what im thinking, i bought a GTO MN12 and it came with the clutch hydraulics complete but i cant use them cuz the master has a no-angled bolt flange to firewall which means i need a new one from/for an F-body, now in an effort to save $ again, my question is this, Can all factory 3rd gen manual hydraulics, pedals, clutch master be-reused and change ONLY the line down to the Slave? I'm not near my car so i cant see how the line attaches to the clutch master side but imagine you could get just the line and swap it out making it a one-part only needed to run an LSX T56....?
ill continue searching...
Old Jul 18, 2011 | 12:44 PM
Re: LSX T56 Hydraulic Line question
apparently the LS1 hose bottoms out where it goes into the 3rd gen clutch master but the guy i talked to said if one could drill out the hole perfectly straight it would work. Of course, i just found out the GTO slave is different from an F-body slave so i have to buy a new one anyway.
Old Jul 18, 2011 | 05:03 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
The GTO slave shouldn't be much different than the F-body slave. The only difference should be the quick disconnect female end that is held into the slave by a roll pin
Old Jul 18, 2011 | 05:14 PM
Dan does that mean i can use the GTO slave with an F-body clutch master and line? i called my father at the dealership and he gave me two different part #'s for the GTO slave and F-body slave, i also called nook and tranny that sells alot of swap parts and he said he couldnt get an F-body line into the GTO slave only a few days ago...??
Old Jul 18, 2011 | 05:23 PM
i searched around LS1tech on the MT board, cant use the GTO slave with an F-body clutch master, the line wont properly insert into the slave.
Old Jul 18, 2011 | 07:48 PM
Engine: LSx 5.3
It will work, follow these 2 links:
http://www.pro-touring.com/archive/i...p/t-49189.html
And just do the opposite of this link:
http://kb.ls1gto.com/KB/article.aspx...0&cNode=5U4I3A
Alot of the GTO guys are buying the F-body slaves and changing out the hydraulic line fitting because the GTO slave is about twice the price of the f-body slave. I'm sure if you post an ad on LS1tech, alot of people probably have the f-body hydraulic fitting laying around.
jharrison5
Aug 19, 2015 05:53 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
rsrmoore
Aug 7, 2015 08:44 PM
