Dyno numbers are in. "Semi Tuned"
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Well, I took the formula to get dyno tuned tonight. Learned alot. Heres mods
67K LQ4 Shortblock Katech Rod Bolts.
LS2 243 Heads Untouched
LS6 Intake, LS1 injectors, and stock untouch Truck TB
85mm Maf
SW Headers with 2.5 collectors
Trick Flow Cam 228/230 580/580 112 cam.
1994 4L60E with 2800 Edge converter
Mild by all accounts.
Got to the dyno on a hot day. It was 90* outside and about 10 more in the shop with thick humidity so I know thats not good tuning weather but we all know "Run what ya brung" After some initial stuff it put down 331 RWHP
Tuned some and it made 347. The tuner noticed that the TPS was showing 86% the entire way. Here my petal wasnt bent enough for the 4thgen cable. Bent some more and pulled 359. Did a cold run and came up with 368. Tuner noticed that this combo should have more in it since it was only at 22* total timing and these cars usually go a little more. We were getting 1.5* retard here and there so we felt it was max, but he added more and took out some sensitivity to see what happened. Up to 24 now. Upon starting up we said something is wrong with the car. The exhaust was SOOOOOOOOO loud. Here on the last run we blew out the muffler. Decided to run anyways and was greeted with 397 and 381TQ LOL. No knock retard also. It was getting late so we are going to go back at it in a week or so with a new exhaust setup and more timing. We easily have 400+ in this car.
Click pic for vid. Also view "Smokey's Dyno" on FB
85mm Maf
Car: Formula
Engine: 6.0 LSX
Re: Dyno numbers are in. "Semi Tuned"
Yea for sure. My uploading the graph now. Any ideas for an non restrictive exhaust? On it now was a 13YO edelbrock setup. Only reason I like it is because it looked stock. It sounds mean as hell now with a blown out rusted setup.
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Car: Formula
Engine: 6.0 LSX
A/F wasnt working right on the last few runs so we didnt run this one any higher. Cant wait to add more timing and see what happens!
Car: 1986 camaro
Engine: ls2
this is what is on my car... hawks 1 3/4 into a 3' collector, flowmaster y, into a 3 1/2 inch single pipe and into a 3 1/2 inch cutout and necks back down to 3' and finishes up the maganflow catback. the maganflow catback is nice and sounds good and isnt relatively expensive.
Car: '89 GTA
Engine: 5.7L LS1
Thats a pretty decent chart, do you have any idea what your WOT A/F was?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Should be alot more left in it with 243 heads and 6 liters. Keep tuning
Good numbers so far
Is that really on stock LS1 injectors?
Good numbers so farIs that really on stock LS1 injectors?
Guest
Posts: n/a
Car: Formula
Engine: 6.0 LSX
White, no idea on that graph. A/F wasnt working on that run. With the prior runs we were around 12:1. This last run was only with 23.5 or 24 timing with 0 retard across the entire run. Were hoping to get 26* out of her.
I'm very happy with this mild combo. 99% all GM stuff and then the trickflow cam. I havent seen anybody else run this cam but I can tell you its awesome.
Car: Formula
Engine: 6.0 LSX
I dont mind loud I just like it to look stock. My car is completely stock looking on the outside and inside. Stock height and everything. Kinda a sleeper look. Thats why I never changed out the Edelbrock exhaust. It has the factory style turndowns. Next it will have a cutout and maybe a 3.5 on there with a single out hidden. Or go 4in? A maggie is in its future. So i dunno.
Car: Formula
Engine: 6.0 LSX
Yup. Stock 28injectors. I got them years ago when SLP had those "take offs" for $100 buck deal. They were not maxed out. It just goes to show you can make power on them and dont need upgraded injectors right away. I followed Pockets fuel system diagram to a tee with with 0 issues. Also running a 9 year old Walbro 255 unit.
I'm prob around 10:1 compression also. No valve float also. I'm using Lunati Beehives which were the cheapest out there, but they performed well.
I think its a good starting point esp for a Automatic.
Also , Jamy is an awesome tuner for Gm vehicles at Smokey's Dyno in the Cleveland /Akron Ohio area. Highley recommended.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I agree with Orr. Just keep tuning and you will exceed 400rwhp easily.
Car: Formula
Engine: 6.0 LSX
The tuner is thinking 415ish probebly. More in colder weather. This heatwave is not helping numbers!! Sad part is, most of my runs were with the car hot, esp the last one. It was right around 220*
Former Sponsor
Car: 91 Firebird
Engine: LSX
Transmission: T400
Axle/Gears: 3.50
Very nice car. I'm suprised at the power increase with the blown muffler.. I've ran mine pretty hard through a single 3.5 over the axle stock style. Maybe I need to open it up...
Car: '89 GTA
Engine: 5.7L LS1
Ok I was just curious about it since you were using stock injectors but it sounds like they are working phenomenally.
Car: Formula
Engine: 6.0 LSX
Well guys , I fell in love with the GMMG exhaust years ago and I always wanted one so I bought one tongiht. The origional maker of the GMMG kits is just about 2 hours south of me in Ohio which made it even better. They build them to order now. He said it should be built by Monday and will be mailed out. Alot cheaper then GMMG marked it up lol. I'm still tossing in a electric cutout as well.
Engine: 4++,350 & 305 CIs
Nice car and numbers. Im a formy fan..
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Sweet car man. Im just south of you I think in the zanesville area. Im working on my Lq4 swap right now. You ever go to national trails and race that beast?
Car: Formula
Engine: 6.0 LSX
I have not been there. I havent raced the car in a few years. If I do race its up at Norwalk which is about 70 miles from me. The closest track is 42 which is about 50 miles away.
Car: Formula
Engine: 6.0 LSX
New Numbers. 419/399 Dynojet this time and 30* cooler outside lol. 65*Now mid 90's in the garage with the old numbers.. Car at 180-190* vs 220-230*
Same tune. I cant wait add more timing. Only at 24* total timing.
Solid combo for basically a cam only car and an automatic. I dont know why I dont see any other person but me running the TF TEA Stage 3 cam.
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
wow those are great numbers, i'm building an LQ9 right now...can't decide on a cam. yours has one of the best splits between hp and tq i have seen yet.
Car: 1989 GTA
Engine: 369 TPI
Excellent, you made the 400rwhp easily. Now to get the timing dialed in.
Car: Formula
Engine: 6.0 LSX
I wonder what 3in collectors on my headers would do for power. Right now they are just the 2.5's
Car: 91 Z28
Engine: 6.0L LQ9
you may see a marginal gain with the bigger collector, may help you scavenge a little more out of the primaries. what is the idle like on that cam, does it have any lope? i really like the torque numbers on that cam, seems like all the popular cams lack in power a bit under the curve...to wide of a spread between peak hp and tq #'s.
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Where is this dyno shop located?
Is that Lipincott doing the tuning?
thx
Jeff
thx
Jeff
Car: 1989 GTA
Engine: 369 TPI
"I wonder what 3in collectors on my headers would do for power"
I am not familiar with SW headers. Are they long tube or short tube headers?
Car: Formula
Engine: 6.0 LSX
The headers are long tube with 2.5 Collectors and to Jeff above, yes Jamy is the tuner. Been friends with him for the past 8-9 years. His shop is located in North Canton Ohio. Top Notch Facility. "Smokeys Dyno"
Car: Formula
Engine: 6.0 LSX
Heres the cam info. Its nice having TEA right down the street and Jamy being good friends with them!
1997-2004 4.8-6.0L LSX engines
Trick Flow® Track Max® cams are manufactured from premium blank cores that are heat-treated to the proper hardness. Then they're precision-ground to exacting tolerances. They are designed and dyno-tested to ensure maximum performance on the street and at the track.
STANDARD FEATURES
Camshaft Style -- Hydraulic roller tappet
Basic Operating RPM Range -- 2,500-6,500
Intake Duration at 050 inch Lift -- 228°
Exhaust Duration at 050 inch Lift -- 230°
Advertised Intake Duration -- 286°
Advertised Exhaust Duration -- 283°
Intake Valve Lift with Factory Rocker Arm Ratio -- 0.585 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio -- 0.585 in.
Lobe Separation -- 112°
Computer-Controlled Compatible -- Yes
Valve Springs Required -- Yes
Camshaft Manufacturers Description:
Street/strip; fair idle, good mid range/strong top-end power, 2,500-6,500 rpm power band, computer modification recommended.
Compression: 10.5:1 minimum.
Quantity -- Sold individually. Notes: Computer modifications recommended for best performance.
STANDARD FEATURES
Car: Formula
Engine: 6.0 LSX
But Im only running a hair over 10:1 compression I think being stock LQ4 dished pistons and 243 heads shaved 10.
The cam drives normal. Excellant for a daily driver!
I will for sure get sound clips for you guys this weekend with the GMMG Exhaust. Smooth idle at 800 RPM's Pulling 14HG's
Car: 1989 GTA
Engine: 369 TPI
With long tube headers you should have a 3" collector. Believe it or not your build is very similiar to mine and if I was using long tube collectors PipeMax calls for them to be 3".
I thought this was interesting in that I am running Dyno Don shorty headers PipeMax calls for 2 3/4" collectors which I did do.
Car: Formula
Engine: 6.0 LSX
Header Pics. As it is, the car runs so well I dont think I will change anything except myabe port and polish the truck TB and maybe a UDP.
the_hamturdler
Sep 22, 2015 02:59 AM
Springster
Sep 13, 2015 01:38 PM
Doobie52
Sep 11, 2015 06:19 PM
nice formula dude
