LSX swap mounts Q
Old Aug 27, 2011 | 04:21 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
LSX swap mounts Q
Will these work? put the C shaped mount on the engine and the rubber on the k member like stock?
http://cgi.ebay.com/ebaymotors/ws/eB...92958269104644
I read the rules and unless i missed it can we post ebay links?
Old Aug 27, 2011 | 04:34 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: LSX swap mounts Q
They will work if you don't intend to have a/c. With most ls accessory configurations, the a/c compressor occupies the same space as the factory clam shell mounts that those adapters work with.
Spohn's mounts use the 4th gen clam shells so that you can retain a/c, although you'll still need to notch the k-member. Another option is to utilize an aftermarket a/c mount that mounts it up high, but those are generally expensive and in my opinion, ugly.
Old Aug 27, 2011 | 06:20 PM
Brando5641's Avatar
Cool thanks for the reply...
I plan on making some custom brackets to move stuff around
i have almost got everything to do this swap
I plan on making a build thread when i get some stuff worth while
PS are all swap mounts 1" set back?
Old Aug 27, 2011 | 08:46 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the spohn/hawks are considered 1" setback. it keeps the motor and trans in the same spot as a regular sbc so no custom drive shaft is required. you can get plate mounts in "standard" and 1" setback, but you'll have issues with kmember clearance with the non-setbacks. i tried both style plates and stuck with the setbacks.
Old Aug 28, 2011 | 06:16 PM
Brando5641's Avatar
The ones in the link are set back right??? They look like they are
Old Aug 29, 2011 | 06:30 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
those are standard, not setback. you can tell because they share a bolt hole between the old and new mounting points. here's a better comparison between the two:
Old Aug 29, 2011 | 03:07 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
That is all i have ever used on 5 or 6 swaps i have done now, they work fine but the best so far has been the set backs that also drop down a touch, the others i had to grind the bolt holes in 1/8th inch to the inside or so.
Old Aug 29, 2011 | 05:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I used those on my LS1/4L60E swap. I used Spohn mounts on the LS1/T56 swap, and personally I don't like the set-back - I still had to notch the K-member for oil pan clearance.
As long as you aren't advertising, you can post eBay links. In this case, you are referencing an item for technical information, which is fine.
Old Jan 3, 2012 | 04:41 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
Bringing this thread back from the dead. I have the Spohn motor mounts and the LS1 clamshells. Does anyone have a picture of how the Spohn mounts line up. Did you have to drill new holes in the Kmember? Also, did you have to notch the kmember for oil pan clearance?
Old Jan 3, 2012 | 06:25 PM
five7kid's Avatar
Do you have the instructions that came with the Spohn mounts? They explain placement and hole drilling.
If you drop the K-member and install the engine on it, then install the two into the car, you can probably get by without notching.
This was before I notched (dropped this one in from the top):
View from bottom w/notch. It would be tight without the notch, but with dropping it from the top, it had to be notched in order to slide in.
Old Jan 3, 2012 | 08:14 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
I didn't get any instructions with the Spohn mounts. I ordered them from Hawks in November. My plan is to drop the engine in from the top and I see what you mean about having enough room to slide the motor in to position.
Old Jan 4, 2012 | 12:16 AM
five7kid's Avatar
Have Hawks send you a copy of the instructions.
Old Jan 4, 2012 | 03:51 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
I emailed Hawks, but I think I figured it out on my own by looking at some pics of other peoples swaps. After looking at it for a while I realized that the front two holes on them spohn mounts need to line up with the back two holes on the K member. Thanks five7. I'm sure I'll have a lot of more questions once my motor gets back from the shop.
Old Feb 2, 2012 | 07:35 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
Tried dropping the motor in tonight. We could get one bolt in on a mount, but the other side is about an inch off. I have no idea what could be wrong here. I have the spohn motor mounts. Labeled L on drivers side of car. Can the clamshells be on backwards? We're scratching our heads here. No idea
Old Feb 3, 2012 | 07:17 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i had a little issue when i was dropping my motor in with the swap plates. found it was easier to leave the bolts loose on the frame side of the mounts loose (nut on so they wouldn't fall out). allowed for a lot more adjustment when trying to get the long bolts in. once all the bolts were in place, tighten everything down and good to go.
Old Feb 3, 2012 | 08:07 AM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
That's what I'm thinking.....I just got fed up with it last night. I got the drivers side bolt in but the passenger side was just a little off. Going to loosen some bolts this weekend and give it another shot. Thanks
Old Feb 3, 2012 | 02:01 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I used simular ones but I just cant remember offhand right now wh made them. Anyways as long as they are the set back ones they will work fine. I also didnt need to cut my K-Member at all like everyone else. I grinded the weld down flat and flattend the area with a hammer and I have a good quarter inch there. I welded solid mounts to my K-member so this wont work if you dont use solid ones but anyways. I liked the adapters as they where good quaility that I got and worked perfect. If I find out who made them ill let you know
Old Feb 12, 2012 | 11:04 PM
Brando5641's Avatar
So do we need to move the k member motor mount location or does the 1" setback take care of this?
Old Feb 13, 2012 | 06:02 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
stock v8 mount location on the kmember.
Old Feb 13, 2012 | 05:19 PM
Brando5641's Avatar
thank god..... i was not looking forward to moving them back.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
