What ever happened to QwkTrip's car anyway?
Old Mar 23, 2026 | 05:31 PM
  #1951
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: What ever happened to QwkTrip's car anyway?
Dang Mr Quick, had no idea..
Glad to hear things are somewhat back to normal.
That ecm failure is a major reason i haven't gone aftermarket yet, expensive and how long will that current platform be supported? Makes me nervous
Old Mar 23, 2026 | 05:51 PM
  #1952
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yeah, HP / Dominator are pretty long in the tooth. I suppose it doesn't take a new high-tech ECM to run an engine though, so maybe the secret sauce is in software which Holley does do pretty well. I did look at other systems but I just didn't want to learn from scratch again with a new system.
Old Mar 23, 2026 | 09:54 PM
  #1953
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Just an FYI but Danny over on the Holley forums sells Dominator ECU's for less than the price of an HP ECU
Old Yesterday | 08:49 AM
  #1954
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Had a warm day so made a bit of progress.
Getting the Mamo 265 heads bolted up to the LS7 has been a bit of a challenge. Trick Flow instructed me to use ARP head stud kit for LS1, part number 234-4317. Problem is they don't know what they're talking about. The larger M11 studs are correct, but the smaller M8 studs are too short. The heads require longer LSx style studs in those locations, which is offered only in the outrageously expensive ARP 2000 material, part number, AFG2-725-2LGB. Just sucks paying another $100 for 10 little, lousy studs.
But the real problem has been the Cometic head gaskets. Every time I remove the heads there has been an oily substance on the gasket compression surfaces. I've done this 5 or 6 times and it keeps getting worse every round, and the gasket coating has been ruined from the clean ups. Cometic is clueless why this is happening and won't help with cost of replacement. So $180 later I have a new set of gaskets... and yes, I'm kind of mad about it!
I ran a little experiment and rubbed a small area of the old gasket with brake cleaner and sure enough, 30 minutes later the oily droplets formed on the surface. The only theory I've got is that the porosity of the aluminum traps some of the brake cleaner in the metal and that ends up contaminating the gasket after assembly. So this time I let the engine and heads air out for 24 hours before assembly. Don't know if it worked and I don't really care any more. Just leaving it alone and moving on.
Final outcome is 69 cc head with 0.040" thick gasket, producing average 0.035" quench, and about 11.7 static compression ratio.
I had something very similar happen to this on my last build and what i found was oil would slow squeeze up out from between the block and the sleeve liners. I might have a pic still.
OUTATIME GTA
Northern California
25
Apr 24, 2012 09:31 PM
TraviZ
Northern California
30
Jun 9, 2006 04:04 PM
jcb999
Jan 31, 2003 01:31 PM
Matthew 4:19
Car Audio
Apr 14, 2002 04:28 AM
