My turbo 4.8l 87 IROC build
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Re: My turbo 4.8l 87 IROC build
Sweet dude. Say, what cubic inches is a 4.8? Like a 290?
Car: 1992 Camaro RS
Hey. I was pretty close.
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Top Secret!?!?!? Is it an intake manifold????? LOL
Car: '89 Camaro
Engine: 4.8, ls9 cam, mpt76
Transmission: Built 4l60e, 3600 stall TC
in progress of doing the same thing in my 89. except I put an ls9 cam in mine and I am running a mpt76 turbo and a 4l60e. where do you plan to mount your turbo? good luck on your build!
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
Its goin to be pretty close to where the battery was. Battery is goin the back
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Dam dude another reject good luck. I read that you sold my old baby. Till this day I miss it, just the part of the memories I had in it. Memories I will never forget.
Tony.
Tony.
Car: 1987 IROC
new part acquired!:
edelbrock low profile elbow
new part acquired!:
Edelbrock fuel rail kit
new parts acquired!:
starter and alternator
box O sensors
used dog acquired!:
Car: 1987 IROC
yeah i think itll fit. with the cowl hood and the low pro and considering how low the motor sits in there.
Car: 1987 IROC
almost got the motor/trans out of the 91. fixin a leak before my boss takes it. might be doin a couple other things and i still get to drive it lol.
time for thanksgiving food!
Car: 1987 IROC
motors out of the 91. gotta change the rear main and put it back in.
did some small things today on the iroc.
sorta painted the engine bay flat black for now and started to smooth my valve covers. think im gonna fill in the lines too.
Car: 1987 IROC
well mostly been workin on the 91 this weekend but did get some work done on my 87.
installed my new slave cylinder, mounted the bellhousing to the trans, intstalled the oil pan and finished shaving 1 of the valve covers.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Valve covers look good. What'd you use to fill the holes in with?
Car: 1987 IROC
JB weld. seems to work pretty good and its sandable when its hard.
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Good job on those valve covers, they turned out real nice.
JB Weld is amazing stuff, I have fixed a number of dirt bike cases in the past with it and they always held up very well.
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
i have two questions on the 87 what did you use to hold that mesh grille in place. and is the whole interior of the 87 black with red carpet? if so can i see some pictures of that?
Car: 1987 IROC
um id have to check on the grille. i didnt do that one my body shop did. the interior is all black but ive been thinkin about doin some red accents.
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
in the one pic the carpet in the rear is red and the panels are black though
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i lied it was the metal truck area that was red. sorry bout that
Car: 1987 IROC
got bored so threw my intake together real quick. should i paint it black?
Car: 1987 IROC
well the theme of the car is red,black and silver.
the engine bay is goin to be black the motor is pretty much goin to be all silver and i think the valve covers are goin to be the only thing thats goin to be red.
Car: 1992 Camaro RS
I'm thinking puse. But black would be cool to. So long as you can do it pro.
Car: 1992 Camaro RS
It does look good the way it is. The matallic grey is a good look.
Car: 1987 IROC
i guess ill see when i put the motor in which will hopefully be by next weekend.
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
ya i say leave it. you could paint it,but then you always have to worry about it peeling off. are you going to upgrade the cam on that motor?
especially since the engine bay is black like mine. trying like heck to add contrast to my engine bay short of pulling, painting, and reinstalling my engine.
Engine: 7.0L
keep it aluminum. and look to see if you can find an ls6 cam or something man, those 4.8's don't like to go over about 5500rpm before they fall flat, and that turbo is going to want to live around 6800 or higher.
Car: '85 IrocZ
I've gotta see pics of those gauges when you're done
I've gotta ditch the mechanical speedo too and will prolly get all new gauges as well. Those look pretty solid!
I've gotta ditch the mechanical speedo too and will prolly get all new gauges as well. Those look pretty solid! Thread Starter
Car: 1987 IROC
thanks to TPI TERROR
new part acquired!:
t56 swap crossmember
new part acquired!:
Car: 1987 IROC
got a little bit of work done today. still gotta finish the 91z. just goin to put the trans mount on tomorrow and then finish up the 91z to give it to the guy that bought it.lol
Car: 1987 IROC
Well if it was primer i would paint it but since its satin black its gonna stay for now.
Car: 1987 IROC
does anyone have a drawing or a pic for reference on where to cut the hole for the shifter?
Install the engine/trans without shifter and tape covering the hole. Mark the 4 corners with a sharpie. Drill and use cutoff wheel to connect the 4 corners
