motor swap help please!
Old Sep 28, 2011 | 11:48 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
on my friends 83 z28 with the t5 borg warner transmission he swapped a 4th gen 5.7 into it instead of the 305. shop told him he needs a 4th gen flywheel for it, would the 4th gen flywheel go with the t5. having issues finding the right clutch/flywheel for it. any help or part # appreciated. thanks.
Old Sep 29, 2011 | 08:56 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: motor swap help please!
LT1 or LS1? That makes a HUGE difference in the answer.
Old Sep 29, 2011 | 02:49 PM
jeff_blake's Avatar
99.9% sure the engine is the 5.7 lt1. not the ls
Old Sep 29, 2011 | 03:47 PM
Jim85IROC's Avatar
If it's an LT1, he should be able to bolt on a stock 153 tooth flywheel for a 1-piece rear main seal block. These are readily available from a number of sources. It's what came on every 86-92 V8 T5 thirdgen.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
