Air cleaner Intake Bellows question
Old Oct 12, 2011 | 02:23 PM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
I would like to use the stock tpi air cleaner system of my 91 Camaro for my ls1 engine swap. Will the 91 bellows work with the ls or is there something else you guys are using.
Old Oct 12, 2011 | 04:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Define "work".
Can it be connected to the LS1 MAF and TB? Yes.
Will it provide sufficient flow to supply the LS1? Yes, as long as you don't go WOT.
Old Oct 12, 2011 | 04:18 PM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Re: Air cleaner Intake Bellows question
Originally Posted by five7kid
Define "work".
in other words not really what I want to use. I just like the looks of it but I suppose I will have to go a different way. I thought it would flow enough air with after market filters.
Old Oct 13, 2011 | 09:57 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
too restrictive.....
Old Oct 13, 2011 | 12:53 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Has anybody proven on a dyno, or even with 1/4 mile times that the stock air box is costing horsepower at stock ls1 hp levels? I see people say this all the time, but nobody used to say it with high power tpi/super ram/hsr/miniram setups that all made more power than a lot of ls swaps.
Old Oct 13, 2011 | 02:23 PM
five7kid's Avatar
I've never had one, haven't flow tested one, haven't dyno tested one.
The "typical" high-HP modified TPI set-up I've seen around this Board replaced it with a high-flow CAI system. Often it's the first mod done to a TPI.
Old Oct 13, 2011 | 02:48 PM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
To be honest I think the cai units make allot of noise and give the impression that the car runs better. Would love to see someone actually do several runs on a car with the both units and compare. I am sticking with the stock.
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
