5.3 questions
Old Oct 16, 2011 | 09:01 PM
pumper.atv's Avatar
Car: 87 Z28
Engine: Truck 5.3
5.3 questions
will this oil pan work?
http://www.jegs.com/i/GM+Performance...12593/10002/-1
also how would you adapt a 700r4 to the 5.3?
What type of wiring harness can i use that i can program with my laptop?
Old Oct 16, 2011 | 09:10 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 5.3 questions
The H8 pan is a no-go. Read the swap sticky for compatible pans
You need the crank adapter to run the older trans or a custom converter with a LSx snub
Any OBDII ready harness will allow you to connect your laptop to the PCM via ALDL
Old Oct 16, 2011 | 09:16 PM
pumper.atv's Avatar
Car: 87 Z28
Engine: Truck 5.3
Re: 5.3 questions
what kind of harness works best
also what program to tune?
thanks pocket
Old Oct 16, 2011 | 09:33 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 5.3 questions
Best is subjective. I dont like to toot my own horn, so Id suggest doing a search on harnesses (covered extensively) and make the decision yourself
Tuning software is also up to you. Most common two are HPTuners and EFIlive
Old Oct 16, 2011 | 10:00 PM
pumper.atv's Avatar
Car: 87 Z28
Engine: Truck 5.3
Re: 5.3 questions
Pocket how do you do your harness?
what did you do for fuel
Old Oct 16, 2011 | 11:05 PM
Iroc'nthe87's Avatar
Re: 5.3 questions
OK, you need to read the sticky threads before you continue, also search this subforum for all of your above questions. Help yourself out and read up on the swap and what is required. I also recommend going through other peoples build threads. Your own desire to pursue something like this should be motivation enough to read up on and know almost everything that will be required to complete this task. Good luck.
neilb
Oct 4, 2018 12:36 AM
z28addict8490
Sep 5, 2015 03:56 PM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
