ls1 swap in 82 z28
Old Jan 31, 2012 | 09:21 AM
Wormdog13's Avatar
Car: 1986 Trans am
Engine: tuned port 305 LB9
Axle/Gears: .323
ls1 swap in 82 z28
I have an 82 Z28 and i am putting an ls1 from a 2002 trans am in it. The problem is that may gauges are completely screwed up. The fuses are good and I already have bought a new cluster. But it still wont work. Would it be easier or even possible to get the cluster out of the trans am and fit it in the Z28? And bypass all of the old wiring?
Please help, thanks.
Old Jan 31, 2012 | 01:31 PM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Re: ls1 swap in 82 z28
all the gauges are messed up? are you using the stock cluster?
Old Jan 31, 2012 | 07:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Wormdog, welcome aboard thirdgen.org.
I moved this to the "LTX and LSX" engine swap subforum.
Yes, you could swap in the cluster from the LS1 donor car. Quite a few people have done that. It's a bit of work.
This might be easier:
http://www.dakotadigital.com/index.c...rod&prd781.htm
You would run new wires to its module (or, at least, you could), so you would probably bypass whatever is causing your mess in the current dash.
Have you gotten the engine running yet? Did you connect both of the large red power wires that went to the battery cable on the starter in the original harness?
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
reiderz iroc
Aug 13, 2015 04:57 PM
