Clam shell
Old Mar 1, 2012 | 11:01 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Clam shell
Why wont the 3rd gen clam shell mount work with the 4th gen tail housing? (700r4-4l60e)
Do the bolts just not line up or what? Is this somthing a welder couldnt fix? I dont want to drop $40 on one if its somethin ez to mod.
Old Mar 6, 2012 | 01:55 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: Clam shell
if you are talking abou the torque arm then there were a couple different designs used by GM.
Old Mar 6, 2012 | 06:58 PM
Brando5641's Avatar
Re: Clam shell
no the CLAM SHELL MOUNT not the T/A, you know the parts that holds that t/a to the tail housing.
Old Mar 6, 2012 | 07:26 PM
1981LT1's Avatar
Engine: LT1; LT1
Re: Clam shell
yes, the metal piece that surrounds the small end of the torque arm had a couple of different designs, and had a different design between an auto or 6 speed.
Old Mar 6, 2012 | 07:30 PM
Brando5641's Avatar
Re: Clam shell
Yes I know this, I was asking what exactly is diffrent from the 700r4 clam from the 4l60e clam shell.
Wonderin if anyone has tryed to put the 700 clam in the 60e and noticed why it wouldnt fit.
Old Mar 6, 2012 | 08:05 PM
1981LT1's Avatar
Engine: LT1; LT1
Re: Clam shell
I'm not aware of any differences for any automatics. However, one wierd thing gm did was to reverse the direction the torque arm faces. Have you verified the bushin is facing the same direction and the torque arm?
Old Mar 6, 2012 | 08:23 PM
Brando5641's Avatar
Re: Clam shell
No I havent pulled the motor and tranny out of the car yet so i dont know whats on the 700, it has been a year or two sence I have pulled a tranny out of one of these to remember.
Old Mar 7, 2012 | 05:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 3rd gen TH700R-4 mount holes and the LS1, at least, 4L60E mount holes are spaced differently.
I don't know if it changed with the LT1 4L60 or 4L60E.
my86bird
Oct 23, 2015 12:20 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
firebirdta84
Interior Parts Wanted
Aug 30, 2015 09:28 PM
