LT1 with a T-5, which starter to use?
Old Mar 19, 2012 | 03:59 PM
solaris_vii's Avatar
Car: 1997 z28
Engine: lt1
Transmission: t56
this may seem like a dumb question as the answer seems pretty straightforward to me, but im in the planning stage and want to make sure i get all my ducks in a row here. going to be doing an lt1 with my t5 to start with (upgrade to tko 500 later), and i need to know if you use the lt1 starter or the starter that you used with the t5. im assuming the t5 starter because it is the t5 bellhousing, flywheel, etc etc, so the lt1 starter probably wouldnt line up with the flywheel. am i thinking correctly here? thanks for any help!
Old Mar 19, 2012 | 05:47 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: LT1 with a T-5, which starter to use?
im pretty sure the lt1 will work and was often used as an upgrade since it was a smaller starter. but yes the t5 should work too
Old Mar 19, 2012 | 07:16 PM
Car: 1997 z28
Engine: lt1
Transmission: t56
good to know thanks!
Old Mar 20, 2012 | 03:51 AM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
My LT1 starter fit just fine.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
