o2 bug position
Old Mar 20, 2012 | 11:16 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
o2 bug position
The drivers side manifold has the o2 bug in a place that is imposible to have the o2 installed. Has anyone els had this problem?
Attached Thumbnails o2 bug position-img-20120320-00166.jpg   o2 bug position-img-20120320-00165.jpg
Old Mar 21, 2012 | 01:30 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: o2 bug position
If there isn't any clearance, what is stopping you from capping and welding a bung into the downpipe?
Old Mar 21, 2012 | 06:34 AM
Brando5641's Avatar
Re: o2 bug position
Well I thought about that but I don't want to mess with the ex. If I don't don't have to. I was just wondering if there is a ez fix some one has found that I'm overlooking.
Old Mar 21, 2012 | 05:13 PM
Brando5641's Avatar
Re: o2 bug position
Well you learn somthin new everyday. Come to find out you can run the car with no o2's so I'm just going to drive it to the ex. Shop right down the road and have them do it.
Old Mar 21, 2012 | 07:36 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: o2 bug position
as you've discovered, the 4th gen manifolds fit, but the driver side O2 port is not optimal. i grabbed a plug for mine off ebay and have the bung located right below mine it the y-pipe. i believe a few people have been able to make it work with certain smaller aftermarket sensors, but its too tight for me to want to risk it
Old Mar 21, 2012 | 10:19 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: o2 bug position
Does simply not having the o2 plugged in force open loop?
Old Mar 21, 2012 | 11:44 PM
Brando5641's Avatar
Re: o2 bug position
Yes and it will run but a little on the rich side but I'm only driving it about a mile to the muffler shop.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
