My LT1/Carb swap.
Old Mar 21, 2012 | 01:37 PM
Notorious0utlaw's Avatar
Car: 1986 Camaro
Engine: 5.7 LT1/Carb
Axle/Gears: 3:42
My LT1/Carb swap.
Hey, everyone Im new to these forums however I noticed alot of people have interest in putting an LT1/Carb in their 3rd gens. I bought my 86 with it all done and it's a blast. However tuning has taken some time. Its 3/4 of the way tuned for the Carb and it get more exciting every metering rod swap and jet change. If anyone has the same carb and have a build of tuning for the LT1 it may save me some time. and if anyone has any questions let me know.
Thanks!
Old Mar 21, 2012 | 05:50 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: My LT1/Carb swap.
Originally Posted by Notorious0utlaw
If anyone has the same carb and have a build of tuning for the LT1.
The carb doesn't know what engine it is on so tuning should be no different than any other
similar spec 350 SBC
Cam specs and Ign timing are going to be major factors in tune
In fact;
your actual tuning problem has nothing to do with it being a LT1 or a engine swap
so the carb tuning question should be asked in the CARB dept
https://www.thirdgen.org/forums/carburetors/
Old Mar 26, 2012 | 01:51 PM
Car: 1986 Camaro
Axle/Gears: 3:42
Yes it is a carb tuning factor.
Needs bigger holes in the accelerator pump. as well as some slight spring/rod tuning.
External fuel pumps are the way to go simple easy to install and take off.
As well if you decide to get a D-body LT1 they are very common at a scrap yard. Where the F-Body or Y bodys are harder to get.
$750 L98
Feb 1, 2025 02:25 PM
rubblerubble
Mar 13, 2016 06:57 PM
usafirebird
Sep 29, 2015 11:58 PM
86White_T/A305
Sep 21, 2015 05:28 PM
el_muerte
Sep 16, 2015 12:01 AM
