corvette c5 pedals for lsx swap?
Old Jun 19, 2012 | 12:14 PM
evo-offer's Avatar
Hi.
I wonder if their is anyone who knows if the pedals from a corvette c5 would fit a camaro för lsx swap?
Old Jun 19, 2012 | 10:30 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
Re: corvette c5 pedals for lsx swap?
they will not work the c5s are drive by wire so they dont have a cable for throttle
Old Jun 20, 2012 | 02:08 AM
evo-offer's Avatar
Doesn't the lsx engine have electric throttle?
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
From my experience, the fly by wire is just the beginning. I have a C5 engine, so I thought I'd keep the fly by wire. NOW I have to fit the silly pedal in the footwell. Already, I have cut it down. Still no easy way. An ace fabricator friend of mine is going to work it out.
I bet the rest of the pedals are just as hard to fit.
Old Jun 20, 2012 | 02:10 AM
Flip 2's Avatar
Engine: C5 LS1
C5 has fly by wire. F-car has throttle cable.
Old Jun 20, 2012 | 02:16 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
depending on resources in your area.its almost easier to keep the thirdgen gas pedal,use the lokar cable and convert to a cable throttle body.flash the ecu to cable setup.
plus i heard its a pita to learn dbw pedal to dbw throttle body and ecu if all 3 parts did not come from the same car.but i dont have experience with that to comment directly.
using 3rd/4thgen pedals for the rest are your best options
Old Jun 20, 2012 | 03:43 AM
evo-offer's Avatar
sounds if it´s the best to use/keep 3/4 gen pedals. wich pedals is best to use for t56 swap? 3 gen pedals of the 4 gen?
Old Jul 1, 2012 | 03:18 PM
evo-offer's Avatar
nobody?
Old Jul 1, 2012 | 05:35 PM
Flip 2's Avatar
Engine: C5 LS1
A lot of folks prefer the 4th gens, I think for the clutch pedal. I used my 3rd gen pedals, and adapting the clutch pedal was an issue. Otherwise they work fine.
Just today, I was reading someone who kept his 3rd gens, cause he heard they were stiffer.
http://www.ls1.com/forums/f124/1989-...q4-t56-162098/
It's buried in this thread, but there is no link to where he heard that.
I think you have to look at what folks have done, and make your choice.
Old Jul 1, 2012 | 05:37 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
you can use either 3rd or 4th gen pedals... if you already have 3rd gen manual pedals you can just keep them and modify the pin for the master cylinder interface... if you are swapping from an auto probably easier to just start with 4th gen
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
85 Jimmy
Sep 30, 2015 07:56 AM
dusterbd
Sep 29, 2015 08:40 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
