5.3 broken damper
Old Jul 18, 2012 | 08:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
5.3 broken damper
My son has a 2001 S10 Blazer that he bought with a 5.3 punched out to 5.7 already installed. He's had it about a year & a half. Along with little things he's had to cope with and fix since getting it, a couple of months ago the Hughes 4L60E crapped out, and he had to have that rebuilt.
Today he called me just before quitting time saying the serpentine belt had come off and the damper pulley was loose. I headed out to where he was ( couple of blocks from home) and confirmed the damper bolt was loose. Went home and grabbed a socket & ratchet, tightened it up, ran it for about 30 seconds and it was loose again, so towed him home. He ran it long enough (after tightening the bolt again) to pull it up the driveway and into the garage. By this time the damper pulley was at about a 10 degree angle (and he said the PS wasn't working as he pulled in).
Pulled the bolt and the damper basically fell off. The sleeve past the front seal had broken clean off. I'm sure it wiped out the crank in the process.
So, if we get a rebuilt crank for it, think we'll need to have it rebalanced, or just put in a 5.7 crank and go for it? For sure the engine is coming out, only question is what goes back in.
Old Jul 19, 2012 | 09:14 AM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Re: 5.3 broken damper
Wow, that sucks! I think I would go ahead and have it rebalanced since the pistons are for a 5.7 bore instead of a 5.3 bore. Are you going to put a stock balancer back on it or go with an aftermarket one?
Old Jul 19, 2012 | 10:05 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you could always pin it while the new crank is being checked out, and definitely look into the rebalancing as well since those aftermarket pistons would have different weights than stock.
Old Jul 19, 2012 | 01:12 PM
dprest68's Avatar
Engine: cammed LS1
Yes, that is what I meant!
Old Jul 19, 2012 | 07:09 PM
five7kid's Avatar
Interestingly the 5.3/5.7/6.0 all show the same replacement crank p/n on the chain parts stores sites.
He's leaning toward going with a new crank and getting everything balanced. We honestly don't know for sure it was bored out to 5.7. For sure it is a 4.8/5.3 block. No idea if the shop that put it together balanced it.
The final decisions will be made after the engine is out and apart.
Also considering putting my "spare" 5.7 shortblock in, at least for the short term. That would probably get him up and running sooner, but would be more work if we put the 5.3 back in later.
Not sure about the damper yet. I'm planning on an SFI unit for the 6.0 when it goes in the '57, so he could have that one. I haven't heard a lot of talk about them being a weak link. I suspect this one either wasn't installed correctly (like bolt not properly torqued), or was damaged when they installed it. Hard to say, and we'll probably never know.
Old Jul 19, 2012 | 11:31 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Although the cranks may have the same number, you still have to watch for the type of rod/piston combo that the crank was on. LS2 rods are heavier than the earlier lq type rods, etc
Old Jul 20, 2012 | 06:22 PM
Pocket's Avatar
Car: 91 Trans Am
If the balancer came loose after tightening the bolt a second time, especially on such a short interval, then either the balancer sleeve is split long ways or has spun on the crank chewing the interference fit to a slip fit. You're looking at a new crank and pulley at minimum
Next, you're in luck as 5.3/5.7/6.0 cranks are the same. GM only balanced the corvette bottom ends (drilled the balancer only), but car cranks were gun-drilled to lighten them. Manufacuring tolerances are much tighter on these engines, so using whatever crank (in good shape) with a replacement balancer will get your son back on the road with minimal fuss
If he's not running a blower, I wouldnt bother pinning the crank
Balancer failures arent unhead of on LSx engines. Usually its the outer ring flying apart, rubber slipping or excessive drag spinning it on the snout
Old Jul 21, 2012 | 01:02 AM
five7kid's Avatar
The back end of the damper sleeve, the part that goes against the crank timing gear, is still on the crank. The damper broke clean from it. The part of the damper we have in our hands that goes over the crank is much bigger than it started out, and the crank snout is for sure chewed up. New crank & damper time. He's thinking he'd like to go through the engine at the same time, as it seems to like oil, too.
Good to hear the cranks are all balanced the same. That sounded right, but I hadn't had time to research it any further.
Old Jul 21, 2012 | 03:27 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
How much did you tighten it? My lower pulley flew off on a test run, in the 6.0. Limped it home, threw a spare on and tightened it with a ton of force and neer had a issue again.
Old Jul 22, 2012 | 11:25 PM
five7kid's Avatar
As tight as we could get it with a bar stuck into the damper spoke and jammed against the engine, and a 24" handle on the socket. It was already toast by that time, we just didn't know it yet.
Old Jul 23, 2012 | 12:08 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Wow thats crazy.How common is this problem?
Old Jul 24, 2012 | 06:14 PM
five7kid's Avatar
I had never heard of it. One of the reasons I posted about it here.
Old Oct 21, 2012 | 11:34 PM
five7kid's Avatar
Well, I'm going to have to eat a little crow here. We pulled the damper off my 6.0 Saturday, and comparing them, the 5.3 damper didn't break off. It just spun on the crank snout. What looked like fracture surface turned out to be metal dust that cleaned right off. But, the part that presses onto the snout was really distorted and enlarged on his damper. The crank snout is roughed up, but a new damper would probably press onto it. We're not going to take a chance, since he wants to do rings and shave the heads while the engine is out. I'm going to be stroking the 6.0 and going to f-body accessories, so I'll give him my 6.0 crank and damper.
I think I've heard of people drilling the crank/damper and pinning them, maybe we'll look into that while it's apart. Cheaper than having crank and damper machined for a key, I'm sure. But, don't want to mess them up, either.
Old Oct 22, 2012 | 07:00 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the crank pin kit is pretty straight forward. get one from ati that has quality pieces and follow instructions. if my buddies with a procharger can do it on his 02 formula, then you'll have no problem with it (he's an economist that doesn't get his hands dirty, and he handled this)
Old Oct 22, 2012 | 03:51 PM
five7kid's Avatar
$120. Not cheap. But, less than pulling an engine apart again.
Guess I'll get one, and some extra pins, and we'll do all our LS engines.
Old Oct 22, 2012 | 04:41 PM
1gary's Avatar
I'm learning from you 57 about the LS's. Kept the posts coming.
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
mfp189
Sep 27, 2015 09:25 AM
