91 B4C 4.8 T56 swap
Old Jul 21, 2012 | 10:48 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
91 B4C 4.8 T56 swap
As many know I wrecked the 89 and now I have the replacement. It is a police package RS, 5 speed with 3.42 gears. I want to try autocross and a cam is in its future. But I also want to see how it will do camless carb only. Ran a 13.87 with the l98 carbed in the 89 with 4.10s, so the smaller cubes and 3.42 will be interesting to compare the difference of the newer tech.
Later I will the the small edelbrock grind, but funds do not permit anyway. 6.0 is going in the TA from the 89 RS, in case you did. OT know and we're curious.
I traded the cammed 5.3 from the 86 TA for this 91 RS, but it also has a 1991 corvette L98 in it that is being removed tomorrow and sold monday with the TPI. I am treading on holy ground to some.
So, here she is, needs 3 pannels that are rather small cut out and replaced that are rusted, the 89 will be the donor.
So, as for those that enjoyed the 89 build, I hope you will enjoy this one as much, even though she will be not as radical, I will try to make this the nicest third I have owned to date. Even will shoot for AC with the carbed setup.
Old Jul 23, 2012 | 01:06 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 91 B4C 4.8 T56 swap
Yoink...
Old Jul 23, 2012 | 11:38 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Hey, theres a guy over on tech doing the same exact swap. I think your is gonna be alot better though
Old Jul 24, 2012 | 08:22 AM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
I'm sure it will be real nice by the time you are done with it!
Old Jul 25, 2012 | 06:23 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
That is the plan, with the cash from the old engine and Trans I an buying a 93 mustang, flipping it to buy a new welder and finish this car and the TA. Have 4 total rust spots to cut out and weld in pannels from the 89.
Old Jul 26, 2012 | 09:21 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Subscribed
Old Jul 26, 2012 | 11:05 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Pulled the tpi harness and ECM, have it sold tomorrow, still need to sell the trans.
Old Jul 28, 2012 | 06:15 PM
Z28FAST1's Avatar
The notorious L98 DELETE!
Curious to see this little monster run.
Old Jul 28, 2012 | 08:16 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Will be holding back compared to the 6.0 that was in the 89. But...a procharger will likely find it's way on to the car as well.
Old Sep 1, 2012 | 07:01 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Forgot to update...
Originally Posted by ZONES89RS
Sold the 4.8 heads, got some 853 LS1 heads, probably going to mill them .030-.040. Started porting them today, used to use pneumatic air tools. Found a Chinese electric grinder with elongated shaft, i still have my hearing and no air compressor to bother me and wait for it to catch up. Used a variable speed router to control it and slow to a usable speed.
But, the work seems better with the extra control, i am no pro but i do work that is free to me and makes more power. Going to use the edelbrock carbed Ls cam, will need a Performer RPM intake as well. The Vic Jr will work for temporary.
Here is some pics, looks better in person but gives you a idea.
After some castrol super clean:
Old Sep 1, 2012 | 07:02 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
And the rest
The tool for the job:
They have a 2 inch valve over the stock heads, so that is why i choose them. I know i may lose a bit of compression but most will be back after milling. This is not a power house so it is fine. Plus i like bragging about 87 octane, LOL.
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 26, 2015 07:54 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
