ls1 manifolds or hawks headers?
Old Jul 26, 2012 | 01:08 PM
evo-offer's Avatar
Hi.
Just curious, but is it worth the 800 dollars for the hawk headers instead of original ls1 manifolds? i´m gonna put in a 5.3 truck engine and keep it almost original except intake.
Old Jul 26, 2012 | 02:33 PM
Fireball's Avatar
Car: 1984 Camaro Sport Coupe
Engine: RHS/LSx 427
Transmission: Powerglide
Axle/Gears: Fab9 3.00 gears
Re: ls1 manifolds or hawks headers?
Originally Posted by evo-offer
Hi.
Only if you want extra power, ls motors usually respond well to exhaust upgrades
Old Jul 26, 2012 | 02:42 PM
evo-offer's Avatar
okey. another question. what dimension is to big for a 5.3 engine? i´thinking of going dual exhaust. 2.5" or 3" all the way
Old Jul 26, 2012 | 03:55 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I swapped in a 5.3 with no cam, a set of shorty headers for a 98-02 ls1 f body are nicer looking and flow better. Manifolds are just for a ultras budget assuming you find them for nothing.
Full lengths are for looks and trying to get the most power.
Old Jul 26, 2012 | 03:57 PM
evo-offer's Avatar
so shorty headers from f body 98-02 works with lsx swap?
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
These were 300$ or so, found then used for 175, fit perfect, you just need the flanges for the y pipe...or whatever exhaust you want.
Old Jul 26, 2012 | 04:01 PM
evo-offer's Avatar
okey. so i can choose wich brand i want then? sounds alot cheaper than hawk headers
Old Jul 26, 2012 | 04:08 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Shorty headers aren't really going to gain any power over stok manifolds if you use the later manifolds. Save the money and use stock manifolds if you don't have a need for the extra power the long tubes will get you.
Old Jul 26, 2012 | 04:26 PM
evo-offer's Avatar
How much gain eould it do with full length headers? Does headers from f body 98-02 full length headers work or is it only the hawk headers that fits?
Old Jul 26, 2012 | 04:43 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Only the headers offered at Hawks will work for longtubes.
Old Jul 26, 2012 | 06:11 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I went with the 2.5's collectors since I got them used. I'm north of 400 RWHP and 11 sec times. No complaints.
Old Jul 27, 2012 | 03:40 AM
evo-offer's Avatar
okay. how much would a stock 5.3 engine gain with full lenght headers?
Old Jul 27, 2012 | 10:44 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
For a mild 5.3 you could probably do just fine with the cheaper imported Hawks headers.
Old Jul 27, 2012 | 10:53 AM
evo-offer's Avatar
okay. Can you send me the link to those headers you mean? i can´t find it
Old Jul 27, 2012 | 11:28 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
or you could get a set of coated mid-lengths from brp hotrods (hedman husler's) for a great price...and have 1 3/4" primaries with a 3" collector. they are specifically made for a 3rd gen with an ls swap. check my build thread for pics.
Old Jul 27, 2012 | 11:45 AM
evo-offer's Avatar
sounds like a good idea. could you link to your project thread?
Old Jul 27, 2012 | 05:05 PM
evo-offer's Avatar
i´ve found the headers and your project thread. how is the quality on those headers? have you mounted them on the engine yet?
Old Jul 27, 2012 | 05:27 PM
Car: 91 Z28
Engine: 6.0L LQ9
the quality is awesome, they have 1700 miles on them in the car....if you read my thread there are tons of pictures showing how they fit on the car.
Old Jul 27, 2012 | 06:17 PM
evo-offer's Avatar
Sounds good. Could you send me the link to your thread?
Old Jul 27, 2012 | 07:26 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Just go to his profile and search for all of the threads he's created. it will pop up.
Old Oct 27, 2014 | 02:18 PM
sickgenz88's Avatar
I have the same question? I just bought a 2002 c5 ls1 engine with shorty headers included.. will they fit on my 3rd gen?
Old Oct 27, 2014 | 05:43 PM
Pocket's Avatar
Car: 91 Trans Am
None of the corvette exhaust will fit a 3rd gen
Since you're here, the C5 batwing oil pan wont clear a factory K-member either. That'll have to be switched for a Fbody version or use a tubular K-member to clear the C5 pan
Old Oct 27, 2014 | 05:52 PM
sickgenz88's Avatar
Yeah got all of that done already just wondering about the headers that came along with the engine. Thanks for the help.
Old Apr 16, 2020 | 03:32 PM
Groot's Avatar
My apologies for grave digging but, I have been searching for an answer regarding Ls1 exhaust manifolds from a corvette. Will these vette manifolds fit down into engine bay on my LQ4.
Old Apr 16, 2020 | 03:59 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
They will physically bolt on to the engine but will not clear the engine mount. So no.
Old Apr 16, 2020 | 11:07 PM
Groot's Avatar
Will the 98-02 fbody manifolds fit?
Old Apr 17, 2020 | 06:49 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I am not 100% certain but I do believe they clear the firewall. I would read the stickies above and search a bit to make sure. I could be wrong. Might want to invest in a cheap set of LS swap headers.
Old Apr 22, 2020 | 12:08 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
ls1 fbody manifolds git fine,but on the driverside if you are using the o2 sensors in stock location..you can put a slight bend in the very top of the sensor to clear.most people relocate when fabbing up a y-pipe.
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
