wich of these lm4/lh6 and l33 is the best for a engine swap?
Old Jul 28, 2012 | 07:56 PM
evo-offer's Avatar
as topåic. why it is just these engines is because i want all aluminum and i´m not gonna ad a lot more power over stock, so i don´t feel that i need a bigger engine. Wich of these 3 engines could you guys recomend? as i´ve got it the lm4 is the exact same engine as lm7 except the alu block, right?
Old Jul 28, 2012 | 09:07 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: wich of these lm4/lh6 and l33 is the best for a engine swap?
LM4 and L33 are Gen 3 engines. It's going to be easier to swap. I think L33 has higher compression ratio, but not sure if that is always true.
LH6 is a Gen 4 engine. It uses E38 engine PCM, 58 tooth reluctor ring, and drive by wire throttle body. That all makes the swap more difficult.
Old Jul 29, 2012 | 01:34 AM
evo-offer's Avatar
Okay. Sounds like it's between lm4 and l33. The compression is correct
Old Jul 29, 2012 | 07:48 AM
Marc 85Z28's Avatar
L33 by far. It has higher compression, 799 heads, and LS2 style connecting rods.
Old Jul 29, 2012 | 07:50 AM
evo-offer's Avatar
okey. good to know
Old Aug 3, 2012 | 08:20 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
i ran the L33, mini-LS1 as i call it, power output isnt much different either in stock form. very nice motor.
Old Aug 3, 2012 | 12:58 PM
evo-offer's Avatar
spunds good. is it really cheapr in the end to go with a truck engine instead of a ls1 directly?
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
