Name that sound.. ugh.
Old Aug 6, 2012 | 12:51 AM
thunder57's Avatar
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
I finally get my motor all wired and cooled properly and I run into this...
New opti, wires, plugs, waterpump, fresh 15W-40 oil. Running 40 psi of oil pressure at 190 degrees F.
I didn't notice this knock in the 1997 donor car, but I also didn't have it at operating temperature. I know the computer is tuned for a LT4 Hotcam, but I doubt it would make the motor sound like this.
I believe it sounds like a bottom end knock, but maybe I could get some insight before I spend money on a rebuild.
Old Aug 6, 2012 | 01:24 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: Name that sound.. ugh.
http://www.youtube.com/watch?v=o0j9a...1&feature=plcp
Im not positive, but on my phone it sounds like it spun a bearing. Like i said though, im on my phone. LTx is notorious for spun bearings.
Old Aug 6, 2012 | 10:52 AM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
I recommend taking it to a mechanic and having it checked.
Old Aug 6, 2012 | 11:14 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
sounds more like rod knock to me
Old Aug 6, 2012 | 02:07 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
I agree on the rod knock and even with the oil you are using..once its switch to something lighter the knock will be more evident.
Old Aug 6, 2012 | 05:44 PM
thunder57's Avatar
Car: 1987 IROC
Looks like it's time for an overhaul. So much for the summer car making it on the road this year. Thanks for the help.
Old Aug 6, 2012 | 05:55 PM
Engine: L31 350
go on eBay and look for a member called kmj performance. They carry re build kits and re ring kits for cheap.
gurkgurkgurk
Sep 14, 2009 06:33 PM
dmair5_0
Sep 26, 2005 10:55 PM
305q_ta86
Jan 15, 2005 09:15 AM
Trans-it
May 2, 2003 01:05 PM
ninety1TAgta
17
Oct 14, 2002 11:43 AM
