5.3 stock/cammed/turbo dynos
Car: 82 camaro z28
Engine: gen 6 454 carburated and cammed
Transmission: ls1 t56 trans
Axle/Gears: currie f9 with 3.70 gears
here are some dyno of the same engine as i did mods to the 03 suburban 5.3 and 4l60 trans
this is when it was all stock with stock ls1 exhuast manifold cutout closed and open
this one is when i added the weiand ls6 intake and a comp cam 222/224 567/569
as you can see now it makes power all the to 6500
now this is with the same set up as above with a garret gt42r turbo /60pound injectors and base speed density tune
blue line are with 4 pounds of boost and the red is with 8 pounds of boost
and this are just pics of the car
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 5.3 stock/cammed/turbo dynos
Numbers look good. How conservative is the 8psi tune? I think my friends stock 5.3 at 9 psi made 570's whp thru but i think with meth inj. Cam id expect a tad more but good nonetheless
Car: 82 camaro z28
yeah its on the safe side right now i forgot it also has a resonator and also depend on the dyno were i take it to,to get tune is dynos higher than my friend dynojet .also go do meth injection in the future. all the dyno charts that i posted
are from the same dynojet
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Nice, one day i will boost a LS, but not yet. Why the newer front nose and older GFX? Or is it just me?
Car: 82 camaro z28
yep your right,86 trans am with the 91-92 front end
I got two questions.With any turbo,isn't it limited to 92 octane gas only??. And doesn't turbo's require more frequent oil changes because the turbo's are so reliant on good clean oil but coke the oil up faster because of heat??.
Car: 89 Iroc-z
Transmission: TH400
You can run whatever gas you want as long as you tune for it. Oil gets hotter and turbo bearings would be more susceptible to damage from dirty oil so more frequent changes wouldnt hurt but you could install inline filters on the feeds to keep particles out if thats an issue
Sorry guy,I am just as curious as a cat on somethings and honestly don't mean to hi-jack you thread.
Car: 82 camaro z28
yeah all the dyno were done using 91 octane pump gas.all the tunning is through a the stock gm ecu.and the is a off the shelf cam from comp cam LS1 XR275HR-12
Car: 82 camaro z28
i would like to see other ls turbo dyno to compare
Car: 89 Iroc-z
Transmission: TH400
My buddys truck
Stock 5.3 longblock with cam and twin 62-1's pump gas plus meth inj
http://www.unitedgearheads.com/showthread.php?t=12422
http://www.unitedgearheads.com/showthread.php?t=12473
ZZ3Astro
Aug 13, 2019 12:57 AM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
