5.3l swap tranny options.
Old Aug 8, 2012 | 11:11 AM
freeagent162's Avatar
Car: 1990 Camaro rs
I'm looking to do a 5.3 swap on my 90rs 5.0. Im getting the motor from a truck of mine with a **** body i'm looking to scrap. i know a lot of people just go with the 4l60e but i would really like to keep my 5 speed. i've never been a fan of automatics. my truck has a fresh rebuilt tranny in it which i was looking to sell for a pretty penny to help fund my build.(this is going to be a budget build) my question is what are my best options for a manual trans? if possible i would like to use the tranny i have now if not i dont want to spend any more then i can get for 4l60e
Old Aug 8, 2012 | 05:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you like your 5 speed, you'll love a T56.
'98-'02 f-body V8 T56 is the ticket. Try to get as much of the clutch/tranny as you can, but if you need replacements, the flywheel & clutch parts will be the same as the '98-'02 f-body V8. You will need a swap crossmember, or fabricate one yourself. Your '90 has an electronic speedometer, so that won't be an issue like it would be for earlier cable drive speedometer models. Your existing driveshaft will even work. I believe you will have to open up the shifter hole in the tunnel, but I'm not completely sure on that (my car was a factory auto car).
Old Aug 8, 2012 | 08:21 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Re: 5.3l swap tranny options.
T56 is the ticket. Sell that T5 to fund the T56, you won't regret it. Plus it's super small 6th gear lets you run a very large rear end gear.
Old Aug 22, 2012 | 10:28 PM
haisud's Avatar
are stock 4l60e transmissions use cooler or not?
Old Aug 23, 2012 | 06:09 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
With 4.30 gears and my T56 I was at 2000 rpm doing 77 mph. 6 speed is the way to go with a manual.
Old Aug 23, 2012 | 06:56 AM
Car: '91 LS6/T56/9"
Engine: LS6
Yes all automatic transmissions need a cooler.
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
