ECM Mount Location pics
Old Aug 29, 2012 | 09:07 PM
cmexlr8's Avatar
Car: 1965 Chevelle SS
Engine: 355
Transmission: TH350
I am going to mount my 95 LT1 PCM in the battery tray area. It is tough to search for pics of how other people mounted the ECM. I want it to be as neat as possible and securely mounted. I am trying to get some ideas on how I want to mount mine.
Attached Thumbnails ECM Mount Location pics-photo_1-2-medium-.jpg   ECM Mount Location pics-photo-2-medium-.jpg
Old Aug 30, 2012 | 01:26 PM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Re: ECM Mount Location pics
I mounted mine under the dash where the airbag used to be (fourth gen dash)
no pics though
Old Aug 30, 2012 | 01:31 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Old Aug 30, 2012 | 01:43 PM
cmexlr8's Avatar
Engine: 355
Transmission: TH350
no pics though
did you lengthen your harness?
cmexlr8's Avatar
Engine: 355
Transmission: TH350
Originally Posted by iansane
That looks to be under the battery tray - did you lengthen your harness?
Old Aug 30, 2012 | 02:15 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Obviously extended .
App 3.5feet to get a good (decent) location away from the engine bay.
Old Aug 30, 2012 | 02:17 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
If you are mounting it in the battery tray area on the drivers side, why not just use the factory caprice/impala/roadmaster mount ?
Old Aug 30, 2012 | 02:23 PM
cmexlr8's Avatar
Engine: 355
Transmission: TH350
What does that look like? I have tried searching but have not found anything yet.
Old Aug 30, 2012 | 05:48 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Man you've got a point on the pics, this is the closest I can find to one showing it, but thats where they're mounted stock, it would be the best choice.
http://sphotos.ak.fbcdn.net/hphotos-..._5904686_n.jpg
Old Aug 30, 2012 | 06:21 PM
88monteSS's Avatar
Car: 92 RS/97 K3500/07 ISS
Engine: LT1/454/LS4
Transmission: 4L60E/4L80E/4T65E-HD
Axle/Gears: 2.73/4.10/3.29
Took me a minute to find it lol, it blended in.
I thought about mounting mine in that area next to my evap canister, but I'm not sure I like having it that close to the front end just in case of a collision. Right now I'm thinking about mounting it on the firewall between the brake booster & fender, but that might change once I get all the accessories installed on the motor & have a better idea of what space is still available. (Speaking of which why is that when I see pictures of other people's engine bays it looks like there's tons of room, but when I look at mine it seems like I have no room at all?)
Old Aug 30, 2012 | 06:43 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
My guess is that youre looking at pics of others bays with nothing in there, and yours complete.
I really wouldnt worry about that location on mounting for crash purposes, if you managed to hit hard enough there to damage the pcm, you've got a lot more to worry about over a $50 pcm.
Old Aug 30, 2012 | 07:46 PM
88monteSS's Avatar
Engine: LT1/454/LS4
Yeah, that's probably a large part of it, plus mine is semi-complete so there's hoses & wires still laying around not going anywhere that make it look like there's more there.
Old Aug 31, 2012 | 12:23 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Originally I had it mounted where the factory thirdgens have them underneath the dash and had to lengthen the harness because I ran it out to the fender. I hear if you drill a 2" hole on top of the frame rail, you can do it without messing with the harness.
With the current location under the battery tray I had to lengthen a few wires but most of them actually were cut shorter.
Old Aug 31, 2012 | 06:05 AM
trigger GTA's Avatar
Car: 92 TA vert
What was there a reason for relocating it from under the dash?
Old Sep 1, 2012 | 12:29 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Yup, I hated seeing all the wires draped over the back of the intake and fender. Moved the fuseblock to right above the battery tray, the ECM to right below and all my wires snake through the frame rail inside the fender brace or under the intake. My engine is naked.
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
mustangman65_79
Aug 13, 2015 07:36 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
