Lost clutch on SBC T56 swap....where to start?
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
Today I lost the clutch pedal...t56 swap on a sbc with a spec 3 puc clutch. The pedal goes to the floor but comes back up. No resistance at all. I didnt see any fluid around the master and the pedals are all still hooked up, no noticeable leaks at the slave but its dark and I hit a puddle while limping it home. I did manage to use the starter to get moving in first and shift without a clutch. The resivor was full so where can i start? The slave or master or could it be the clutch?
Engine: 4++,350 & 305 CIs
Re: Lost clutch on SBC T56 swap....where to start?
The seals could be bad in either the master or the slave.
Car: 1987 Camaro
Well I rellaced the slave because the old rod was bent. Still no pedal but it was bench bled and had plenty of fluid out of the bleeder valve. Does that mean new clutch time?
rsrmoore
Aug 7, 2015 08:44 PM
