turbo headers
Old Sep 8, 2012 | 06:03 PM
89fbrestor's Avatar
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
turbo headers
anybody know of some good turbo headers that will fit our engine bay?
Old Jan 13, 2013 | 02:20 AM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
Re: turbo headers
ever find any?
Old Jan 13, 2013 | 09:54 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: turbo headers
flip over the f-body manifolds. perfect budget header
Old Jan 13, 2013 | 10:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: turbo headers
STainless works makes a front forward set. about 800-1000 a set
They have sbc ones and lsx ones and both should fit the bay. Then put turbos behind headlights or run a single up front somewhere
Old Jan 14, 2013 | 01:21 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
Re: turbo headers
this looks like it might fit
http://www.shop.trickperformanceprod...o-Manfiold.htm
Old Jan 14, 2013 | 01:22 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
Re: turbo headers
will that clear the hood?
Old Jan 14, 2013 | 07:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: turbo headers
Originally Posted by BADASS91B4C
My buddy ran a similar setup as that, fabbed out of mild steel. Made 700 whp on a gm 4.8 truck motor with pt88 turbo
Old Jan 14, 2013 | 08:15 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: turbo headers
Yes, just angle the turbo flanges correctly when you weld them on the manifolds. Heat up the manifolds and weld them, do not braze them...
Old Jan 15, 2013 | 06:20 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: turbo headers
I made a 98-99 fbody work on the driver side flipped,triangle cut off and vband welded on.
Pass side used truck manifold flipped with triangle cut off and vband welded on.
Worked great with tc78 turbo. The turbo was in the area where the rad overflow tank goes. The manifolds cleared the mounts and everything else.
No ac
Old Jan 15, 2013 | 06:30 PM
ihatemustangs's Avatar
Car: 74 z28, 89 IROC, 98 Z28, 91Z Vert
Engine: 383, 350, 347, 305
Transmission: th400, 700R, T-56, 700R
Axle/Gears: 3.42, 3.45, 4.10, 3.08
Re: turbo headers
I had a set made, and a crossover. Look up my name on here, its all for sale
Old Jan 15, 2013 | 09:57 PM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Re: turbo headers
No ac
I'd love to see some pictures if you have any?
How did the fbody manifold fit on the driver side? I know the truck one goes right through the gear box if not mistaken.
Old Jan 16, 2013 | 01:12 AM
Car: 02 SS
Re: turbo headers
Yes, the truck manifold crashes in the gear box. The camaro can clear with the triangle flange still, but depends on the mounts used. I used some of the sbc/ls swap 50$ 3/8 plate adapters. They worked fine. But wanted better sealing and used vbands also from ebay. 2.5 crossover, 38mm 2bolt wg, tc78, hks bov.
Thr pass side used a cast iron truck manifold. I do have pictures on my other pc. I eill dig em up. I used the early stamped 98-99 manifold. Although the cast iron 00-02 should work also. Since the shape is very similar.
Old Jan 16, 2013 | 04:03 PM
89fbrestor's Avatar
Re: turbo headers
i ended up doing this. i know its not pretty but a couple hours with grinder... or days and i'll be happy with them lol 1 3/4 primaries to a 3 1/2 collector. aside from having a cheap flux core welder, i think for my first header build they came out ok.
Old Jan 17, 2013 | 01:35 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: turbo headers
pics pics pics!
Old Jan 29, 2013 | 10:21 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Re: turbo headers
Originally Posted by xpndbl3
pics pics pics!
Bumpppp for pics!!!!!
Hotrodboba400
Dec 10, 2019 07:07 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
