89' 700R4 will it work with a 96' LT1??
Old Nov 7, 2012 | 10:24 PM
C201969's Avatar
I've got a 96 LT1 (out of a Caprice) that has been sitting for a bit and a a 89' 700R4 out of a G20 van. Does anyone know if it is possible to get the two to work together? (electrical) I've swapped LT1's before but they were complete matching engine to trans. Any info would be helpful.
Thanks for your time
Old Nov 8, 2012 | 01:54 AM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Re: 89' 700R4 will it work with a 96' LT1??
Yep, but you will need a detent cable, intake bracket, throttle body add on bracket, Tcc lock up and vss adapter thingy. Or if you just want it in now, it will bolt right up and you can rigg up a tv cable bracket and drive it with no speedo and tcc, but it's not advised but it can be done.
Old Nov 8, 2012 | 05:09 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by 89rs454
you will need a detent cable, intake bracket, throttle body add on bracket, .
92/93 LT1 throtle cable bracket has provision for mounting the TV cable you need with the T700
http://www.ebay.com/itm/92-93-LT1-Ca...c8e9eb&vxp=mtr
92/93 LT1 TB has the stud for the TV cable to fit to
TCC control options here
https://www.thirdgen.org/forums/carb...c-control.html
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Reddeath210
Oct 6, 2015 08:20 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
Leggman1
Aug 6, 2015 04:15 AM
