Will a SBC T56 setup bolt directly to a 5.3?
Old Nov 8, 2012 | 03:50 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Basically my shortblock now is screwed up. Weighing the pro's and cons of building a stout SBC shortblock vs switching to a LS motor. I can get a complete 5.3 for cheap, so now I'm trying to price out what everything would cost to get it in the car and driving.
My question is with the trans in particular. I'm currently using a bit of an odd combo. Its a T-56 out of a '03 Cobra with a LS input shaft, 1" billet adapter, Lakewood bellhousing, and a Ram clutches hydraulic throwout bearing. Not a LS bearing though. Can I just bolt this setup to the 5.3 or not? In order to use the adapter plate I had to cut the tube off that the throwout bearing normally rides on on the mid plate. The adapter has the tube built into it. Hope this makes sense. Just needing to know if I'm going to have to buy a new T-56 mid plate, LS bellhousing, and LS throwout bearing or not.
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
