PCM controlled fans with 2000 5.3 setup.
Old Jan 17, 2013 | 11:38 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
I am helping a friend do the wiring harness for a 5.3 swap into a older carbed car. His engine, PCM, and harness are all from a 2000 5.3 Chevy truck. He wants the PCM to control the electric cooling fans. It appears the 99-02 ls1 PCM and his PCM have critical functions pinned the same, so would it be possible to use pins b42 and r33 like a ls1 PCM, and have the electric fan function turned on in the PCM? If not, is there any way to do this short of switching pcms?
Old Jan 17, 2013 | 08:50 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: PCM controlled fans with 2000 5.3 setup.
you would have to get a custom tune for it to work. a 5.7 pcm might work but I doubt it. with a custom tune and the correct relay harness the 5.3 pcm will run the fans.
Old Jan 17, 2013 | 08:55 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
He already needs a tune due to removing emissions and stuff plus a cam swap. Nice to know it can be done, but would b42 and r33 be the correct pins to use?
Old Jan 22, 2013 | 12:05 AM
Rick 83Z's Avatar
Car: 83 Z28
Engine: Junkyard 5.3 F1A Procharger
Transmission: 4l60e
Axle/Gears: Moser 9"
I am building a harness for my 2002 5.3 and those are the pins I am using to power my fan relays. If you go to lt1swap.com, everything you need to know as far as PCM pinouts and wiring a stand alone harness are covered.
Amillionoh7
Sep 11, 2015 11:36 AM
64goatman
Sep 9, 2015 01:09 PM
Jlanz55
Sep 6, 2015 02:35 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
