Using Truck injectors on LS1 Intake/Fuel Rail
Old Jan 25, 2013 | 07:59 PM
croozer's Avatar
http://www.summitracing.com/parts/fs...s/model/camaro
Found these, was wondering if anyone could verify that these in fact would work to use the shorter truck fuel injectors on the stock LS1 Intake and Fuel Rail?
It seems more and more common that people are turning to truck motors in their swaps instead of paying the hefty cost of LS1/2/6/etc. This could potentially save $100+ on injectors and $xx on injector connectors.
Thanks!
Croozer
Old Jan 26, 2013 | 12:54 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Using Truck injectors on LS1 Intake/Fuel Rail
Truck injectors are the smallest of all LSx injectors. Put a cam in and they're maxed out
With used LS1 injectors commonly at $50 or less being more injector than most people ever use, why try to save the inferior parts? If you're that cheap, reuse the TPI injectors. Same height as the LS1's and same flow as the truck parts minus the unique connector
Old Feb 7, 2013 | 08:21 PM
croozer's Avatar
I don't plan on putting a cam in this engine. I am just trying to get the vehicle rolling under its own power. It doesn't have to be fast. It's a budget build, I'm trying to see how cheap I can do it. So it boils down to are these the spacers I have heard mentioned off and on that will allow a truck style injector to work in the taller car style injector space?
Thank you for your assistance,
Croozer
Old Feb 15, 2013 | 07:10 AM
Pocket's Avatar
Car: 91 Trans Am
Use the truck fuel rail and injectors on the LS1 intake then
sweet_87_iroc
Sep 25, 2015 10:01 PM
mike_c
Aug 27, 2015 04:32 PM
hayesaw0210
Aug 23, 2015 11:15 PM
ezobens
Aug 19, 2015 10:29 PM
