Craigslist Searching + My Apartment Room + LSx = ?????
#201
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Craigslist Searching + My Apartment Room + LSx = ?????
Little update was having issue with fuel level sender for some reason it always was reading full but it was dead empty so pulled it out and mess around and stretch the metal piece out amd cleaned it up and corrected the issue tried to prime fuel line but noting came out fuel line tried to prime it couple time just be turn to on position but nothing only put 2 gallons so im make some runs and add more fuel as it been sitting dry and im going to double check some fuel lines for kinks and done correctly but i sure its done correctly ,i use one rubber hose im im pretty sure its kink so im re adjust it
#202
Engine: 305 to 350
Axle/Gears: 10 Bolt
Will get better pics soon also , installed Ground Control
And installed tge Apex Arc 8 wheels there 18x10 all around with 275s
And she will be clayed ,rubbing, polishing in wax did and small portion paint still doesnt look half bad ...time to get this milk bucket back on the street
And tinting also 35% side 20% rear ,yellow fogs, hid projector retro fit , and full shampoo clean interior
#203
getting there, good luck with the fuel issue!
#206
Engine: 305 to 350
Axle/Gears: 10 Bolt
Tried to start almost crank up till starter broke going to get new one today i had older starter design so newers desigb is way stronger
#207
Car: 1986
Transmission: t56
Axle/Gears: Auburn 3.73 posi moser axles
what kind of strut bar is that? You can't see the label from the picture, but your setup looks good with the black and gold
#208
Engine: 305 to 350
Axle/Gears: 10 Bolt
A eldebrock one IIRC qa1 makes them now
#209
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Looking good im barely gonna start mine in two weeks. Have you gotten it started?
#210
Engine: 305 to 350
Axle/Gears: 10 Bolt
I tried to start till starter mount snap off battery was low so 1 waiting for stronger updated starter to come in and 2 need to charge battery, so thats pretty much holding me back right now
#211
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
You still living down in san diego? Id like to check it out in person.
#212
Engine: 305 to 350
Axle/Gears: 10 Bolt
No im near pendleton now
#215
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea you can see where the old style starter where mounting is snap off and its about a inch thick so not very strong most of the load is on that bolt also so witgmh age and it being stressed can form cracks
It is a weak point some people have issues others dont as yoy can see witg new style it a large chunk of metal so you need to long bolts
On another note replace starter , tgen batter was completly dead so charged it tried to start it just back fires and wheb applying gas it turns on and runs but as i let off it just shuts off
First thought that comes to mind is VATs in computer wasnt ever turned off when i sent in to get mail order tune for 42lb injectors either i forgot to say it or they forgot
What you guys think , im not to familiar with vats for ls1 but i assume its same as tpi but car starts so that throws me off as i thought vats completly shuts off fueling
#216
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
VATS will allow max 3 sec of run time. If you can feather it and get it to run longer, it needs a tune
The only time Ive seen LS1 starters snap like that is when they use the starter and a breaker bar against the ground to loosen the crank bolt
#217
Engine: 305 to 350
Axle/Gears: 10 Bolt
Been reading also where it could be a MAF either leak or bad sensor
Yea i wasnt feathering it but doesnt even idle only when pushing trottle about 60-90% down it begins to come to life till i release and it just shuts down no idle or nothing
Im beginning to think if they even loaded the fuel chart for the 42lb injectors and left the stock tune for stock injector size , i only paid the guy 80 i think i prob just send to frost or EPS since thats where i got my cam from
#218
Engine: 305 to 350
Axle/Gears: 10 Bolt
So tried again and some times it starts and run time is around 2 sec then shuts off but I feather it and runs little longer but let off gas shuts off going send computer out this weekend to get tune , but going to look locally for tune shop for faster turnaround time
#219
Engine: 305 to 350
Axle/Gears: 10 Bolt
I got mines off ebay , but iirc there from truck so pretty much just buy the truck version , i wouldnt stress to much about it , mines broke for some weird reason i got it used so who knows i might of already been cracked and i just finish it
#221
Looks great dude. That's exactly how I want mine to sit.
I thought about that as well, but the money on the crank and valvetrain is immense.
Thanks . thats what i fiqured. worst question is the one you dont ask right lol
would be cool to get ahold of a flat plane crank to spin 7000+ with ITB Intake ..that would be sick setup and sound amazing especially with 180 exhuast .. talk about a 24 Le Mans in your drive way
#222
Engine: 305 to 350
Axle/Gears: 10 Bolt
thanks
little update sending computer back out to redo tune if it ever was done
#226
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea i was going to do myself but parts came out to be the around the same price plus he has sales every so often so its decent price
https://www.thirdgen.org/forums/auto...-lighting.html
#227
Car: 1986
Transmission: t56
I really like how these lights look on these cars especially when people have the dummies in there too
#228
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea i got dummies also
#229
Car: 1986
Transmission: t56
Its hard to tell what the difference is btw all the center pieces. Is it just what the outside edge of the center section looks like? Or does the lens change? It looks like you got the gatling guns. Did you just order that center just off a guess? Or was it something you saw before because they look sick. There are so many to choose from on his website.
#230
Engine: 305 to 350
Axle/Gears: 10 Bolt
Just pic the one you like and any color combo you want its chrome with a tint so no guessing here i know what i wanted and the look i was going for , so it wasnt hard for me i dont like chrome or alot of bling i also didnt want it too dark so tinted chrome seemed to be the happy medium
#231
Car: 1986
Transmission: t56
Thanks for the good incite man. I definitely going to have to get some for my car, the lights are the worst part of our cars.
#232
Engine: 305 to 350
Axle/Gears: 10 Bolt
So i pulled the plugs out getting spark in all but cylinders 3,4 and 6 others plug are black so i know its running rich so after i get off ill trouble shoot that and see what i find
#233
Engine: 305 to 350
Axle/Gears: 10 Bolt
Forgot to mention that the spark plugs on cylinders 3,4 and 6 look like new still no black residue from ignition
injectors are new
Im kinda thinking plug wires are not seated all the way some how or there bad
Sigh
injectors are new
Sigh
#235
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea i agree and im thinking its the injector , as i check one cylinder and got spark at the plug im try other 2 and see if i get the same results
I regapped all plugs too .050 most of them where less than .030 range ,but really doesnt explain dead cylinder
Im run codes when i get the hptuner i got used just waiting for the cable to come in this week
#236
Engine: 305 to 350
Axle/Gears: 10 Bolt
So check injectors getting power to injector ran spark plug and getting spark at injector to cylinder execpt number 4 and so i swap wire around and nothing and swap coil around and nothing so check if i was getting power to coil from connector to coil and i am getting that
Smh frustration kicking in now lol
#238
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea Thanks , Yea calling it quits tonight still same issues, I really do need to do a scan now after the trouble shooting
#239
Car: 92 Firebird
If you've got spark, then its a fuel issue
Move the injectors to other holes and try again. If the dead cyls follow the injectors, then they are the culprits
#240
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea hope not then I would have to send them back so they can look at them they where rebuilt etc by FIC but will try tomorrow
Well cylinder 4 wasn't getting no spark, but removed plug and threads where wet and smell like fuel ,
also which is weird I switch coil around and still same thing which has me confused a bit with the trouble shooting part as when I remove coil back it work on the other cylinders
And when removing spark plug I smell fuel so I believe there's some type of fueling going thru injectors
Could it be I don't have good ground , I ground left and right head for harness and then I connected them together with a wire then from passenger head I then grounded that to body and then battery is then grounded to same passenger head side , I don't think I have a ground issue lol
Idk but there's something goofy going on
#242
Engine: 305 to 350
Axle/Gears: 10 Bolt
From what i was reading that was a 98 harness thing and 99 up didnt have that issue ?
Ill try it tho
Ill try it tho
#243
Car: 92 Firebird
If the coil harness hasnt been disturbed, dont worry about it
Grounds are easy. The 2-3 from the harness need to be securely bolted to the cyl heads. Ground cable to the block, engine to chassis ground. Done
Single coil dead is often a bad coil. Move it and see if the no-fire follows it
#244
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea non fire doesn't follow I switch 4 different coils and plug wires , did it like 4 times yesterday lol will double check everything again
Coil harness was taken apart to be cleaned so they could be flip but harness only goes one way idk but I'll try flipping them
#245
Car: 92 Firebird
Might be the coil harnesses are reversed, look at the colors
Pnk, Brn, Blk are present on all 8 plus another color
1 PPL
3 LT BLU
5 DK GRN
7 RED
2 RED
4 DK GRN
6 LT BLU
8 PPL
Ill check tomorrow when Im at the garage, but the coils are supposed to be wired so each group can be fitted to either bank without changes
1 PPL
3 LT BLU
5 DK GRN
7 RED
2 RED
4 DK GRN
6 LT BLU
8 PPL
#246
Engine: 305 to 350
Axle/Gears: 10 Bolt
I flip harness still same thing , I switch coils around and still no spark on cylinder 4, I ran a scanner and got codes p0452, p1860, and p0356
Then
Fuel sys 1 - OL
Fuel sys 2 - OL
Calc Load % - 1.2
ECT F - 66.2
STFT B1 % - 0.0
LTFT B1 % - 0.0
STFT B2 % - 0.0
LTFT B2 % - 0.0
MAP inHg- 29.8
MAF lb/min - 0.5
TPS % - 0.0
For code p1860 when I had tran apart I notice it was crack abit at terminal so that's easy fix to replace
All injectors have batt 12v+ when in run.
All pcm batt+ (Blue 20/57) and ignition batt+ (Blue 19) are good
All PCM ground pins are good. Pins 1 & 40 on Red and Blue.
All coil connectors have 12v+ ignition power in run
All coil connectors have proper signal wires. Continuity from PCM connectors to individual coil connectors is good and proper pins.
Coil connector to engine block grounds are good.
Coil connectors PCM low ref to PCM pins continuity is good.
Plugs are brushed and blown clean. Engine is pumped clean from any flooding situation. All subsequent tests have been done with injector fuses and fuel pump fuse pulled. Injectors all fire which was causing flooding on cylinders that don’t have firing coils.
All injectors prime and pulse
All spark plugs product spark if coil is proper signalled and fired. EXCEPT CYLINDER 4
If crank and cam sensor where bad it should of pulled a code so I can safely say there good ???
I'm tap out think I did everything I could to rule fueling out and air sensors etc , so going to drop a pretty penny and replace all coils ugh
Then
Fuel sys 1 - OL
Fuel sys 2 - OL
Calc Load % - 1.2
ECT F - 66.2
STFT B1 % - 0.0
LTFT B1 % - 0.0
STFT B2 % - 0.0
LTFT B2 % - 0.0
MAP inHg- 29.8
MAF lb/min - 0.5
TPS % - 0.0
1 PPL
3 LT BLU
5 DK GRN
7 RED
2 RED
4 DK GRN
6 LT BLU
8 PPL
1 PPL
3 LT BLU
5 DK GRN
7 RED
2 RED
4 DK GRN
6 LT BLU
8 PPL
#247
Engine: 305 to 350
Axle/Gears: 10 Bolt
Any body know where to get a package deal on some coils
Or could it be a Bad PCM as I'm getting spark at plug cylinder 6 ?
Engine will run when giving it gas with backfire and rough idle Due to Misfire
#248
Car: 92 Firebird
Pick up another set of coils or order them off rockauto for cheap
Do a continuity test from the coil white connector to the indiv coil. The old harness may have a break in it. Very strange its coding #6 and dead on #4
#249
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea i did that there 12v power at all 8 coil connectors with ign On , i havent check for signal from pcm but i figured if im getting power then it should get signal , ill be getting a volt meter and test hertz to see if pcm sending signal , yes i inspected harness and theres no breaks
Sigh i dont mind trouble shooting but im stumped because this strange
Forgot about rockauto i know ebay are decent price cheap
#250
zach i had an issue on a fuel injector i chased for over a year. it would come and go. it ended up being in the "sealed" part of the connector. the wire was broke loose from the pin and would intermittently not make contact throwing a code. so maybe your issue is inside the connector?
