Magnacharged LS1: Dyno Results
Old Mar 9, 2013 | 09:23 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Finally made my way to a dyno session after my final tune.
This is a GTO TVS1900 kit on a 2000 LS1.
Engine is stock, heads are stock 853's with Crane dual springs, and essentially a Thunder Racing blower cam (214/230 .601 / .578 117 LSA).
Exhaust is Hawks 1-3/4 long tubes, 2.5" y-pipe, 3" exhaust with flowmaster muffler.
Maggie has a 102mm TB, bored out snout, and 3.05 pulley. Maxes out at 8.2PSI.
Speed density tune, big air filter to a straight 4" pipe on the intake. Judging by the cutout open effects, I need to rework my exhaust.
First run, cutout closed. 497HP, 471TQ:
Second run, cutout open. 507HP, 491TQ:
Works for me!
Kevin D.
Old Mar 9, 2013 | 09:29 PM
BlwnSS's Avatar
Car: 1999 Formula Hardtop
Engine: 6.2 forged ls3 Procharged
Transmission: t56 Magnum
Axle/Gears: midwest chassis fab 9/3.50
Re: Magnacharged LS1: Dyno Results
nice running 3rd gen with ls style . Ive seen a few guys on ls1tech with maggies and your at about the max of that setup . That must have so much tq down low . Very nice.
Old Mar 9, 2013 | 09:35 PM
shr00m's Avatar
Yeah, that torque number was a bump at 2900, fell to about 475 at 3500. Just about flat until 4700, and then trailing off to around 400 by the time I hit the rev limiter.
With 4.11's and a 6-speed, it's quite fun.
Kevin D.
Old Mar 9, 2013 | 09:39 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
nice numbers... So what do you think, is the cutout HP/TQ bump is worth the noise? I have one on my car and it wakes the dead.
Old Mar 9, 2013 | 09:50 PM
shr00m's Avatar
Hell no! I like the stealth / sleeper approach, and the cutout does not fit into that. Dyno guy wasn't even going to strap the front down until I popped the hood. I've got an electric one I've broken twice, looking to get one that fits better. I mainly used it for the track & making noise.
When I went to the dyno I was running a standard bolt-on plate, and run 2 of 2 went 497. The guy hosting the event said it was a shame I wasn't turbo, we could have cracked open the wastegate just enough to hit 500. I said we could try the cutout and he was pissed I didn't run it with it open to begin with. Gave me a free run just to see.
It's good to know when considering larger headers/3" collectors though.
Kevin D.
Old Mar 9, 2013 | 09:59 PM
Car: 89 Formula 350
Kevin D.
Yeah, I only open mine when I'm looking for every possible HP. I still haven't gotten rear wheel dyno number testing open vs. closed. Hopefully this spring sometime. I also had bad luck with the first 2 electric cutouts leaking. I went through 2 Summit brand Chinese knock offs before switching to a QTP cutout- much better.
Old Mar 9, 2013 | 10:24 PM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
I don't think I could've said this any better myself
With Hooker Shorties on my old 305, it wasn't extremely loud with an open cutout (in place of the cat). Startup was loud, but once it was warm, it wasn't anything to go deaf over. For the last few months before winter teardown, I actually drove it with the cutout always open. Didn't draw any attention from law enforcement, but then again I always just coasted past if I saw any lol. This year, I'm running mufflers though. Longtubes with a bigger motor and bigger exhaust valve, probably a bit louder. Dual 3" Thrush mufflers after the longtubes, see ya ground clearance.
Old Mar 10, 2013 | 12:49 AM
shr00m's Avatar
Not a Chinese problem on my end. Have a Raceready model that I tucked up all nice and tight. Hit the intermediate pipe backing out of a driveway and smashed the motor into the body. Finally got the motor replaced, re-installed it so it had clearance around the body, and about a week later ripped the gears open hitting a speedbump. The design of it makes you have the motor facing up or down, no happy medium.
Thinking of going with the Raceland unit. Slightly larger, but should hold up a little better on not hang down or up.
http://www.racelandus.com/exhaust-sy...st-system.html
Kevin D.
Old Mar 10, 2013 | 01:02 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
nice numbers and setup.are you dynoing in 3rd or 4th gear?
Old Mar 10, 2013 | 01:11 AM
shr00m's Avatar
4th, 1:1 ratio in the T56.
Kevin D.
Old Mar 10, 2013 | 01:14 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
ok just making sure you were in 4th.hard to hear lol. ive seen guys dyno the 6spd in 3rd and praise their in accurate high numbers before and had to burst that bubble.
very stout street rod right there and love that its stealth looking aside from being lowered
Old Mar 10, 2013 | 01:35 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
couple things:
get a lower numerical gear.
your exhaust can be improved, maybe try building a slick true dual setup? if you want the sleeper sound, it may be the way to go, otherwise one of the established companies may have somethin for ya.
Old Mar 10, 2013 | 10:03 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
I'd be proud to drive that car!! Nice work, looks great too.
Old Mar 11, 2013 | 02:41 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Great work as always. The car is looking good !
Old Mar 11, 2013 | 10:26 PM
my88transam's Avatar
Car: 1988 Trans am
Engine: 305 TPI, LS1 in progress
Transmission: T-5, MN12(GTO T56) in progress
Axle/Gears: 10-bolt/308
what head gasket are you running with those 853's? By stock do you mean stock compression, and bottom end as well? Just curious because I've read that the 853's are limited with head gasket selection because of a notch in the heads. Great set up by the way!
Old Mar 13, 2013 | 10:45 PM
shr00m's Avatar
Stock head gaskets and bottom end. Only things done are standard cam swap items, ported LS6 oil pump, new timing chain, cam, and springs. Heads have never been off the engine.
Kevin D.
Old Mar 14, 2013 | 05:06 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Transmission: 4L60E 3,200 Edge stall
Axle/Gears: 9 bolt w/3.90
No blower here but I'm running Hawk's 1&3/4 swap headers with the 3 inch collectors that go into a custom 3 inch Y with dual cut-outs, then to a 3 inch magnaflow exhaust. On the dyno, we put down 14 more hp with those things buttoned up. I know, go figure. We never intend to use the cut-outs again. Your car might like something like the 1&7/8 or 2 inch headers with 3 inch Y and a big (non-flowmaster) cat back. I bet you'd see the 500 pretty easy without opening the cut outs.
Attached Thumbnails Magnacharged LS1: Dyno Results-2012-02-16-16.56.52.jpg   Magnacharged LS1: Dyno Results-2012-02-01-21.09.18.jpg   Magnacharged LS1: Dyno Results-2012-02-01-11.43.56.jpg
Falcon50
Aug 22, 2020 03:26 PM
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
