Ls1 to 6.0 question...
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
I just bought a 6.0 from a 99 2500 hd
The queston is am i goin to have trouble with the flywheel and starter are the ..
Im putting all the Ls1 heads brackets intake everything im alreading ready to put oil pan oil pum and all my bottom end need help please...!!!
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: Ls1 to 6.0 question...
the starter and flywheel are the same and all the LS brakets will work but I believe one bolt hole or the alt will not be drilled on the 6.0
Engine: ls1
Transmission: 4l60e
its just that i look at the crankshaft and at the end it looks like its farther back than ls1 crank... its a 99 where the rear main goes it looks like double the thickness
you will need a LS1 balancer they are internal balance so you can swap them out and yes the 99 to 02 6.0 has the longer crank snout so it will bolt to any older trans 700 th400/350 but will not work with a newer 4l60e but will work with a older t56
you need a block that is 02 up they used spacer to bolt to the 4l80es the 99 to 02 just bolted up
Engine: ls1
Transmission: 4l60e
So there is no way i can get my 2000 4l60e to fit..?? And would a 4l80e thats 4x4 work..?? Thanks for the help...!!!
the 4l80e will work perfect but you will have to take it apart and replace the output shaft at the rear to a 2wd shaft and the 4l80e is a BA trans shift kit alone is good to 550 hp its a th400 with overdrive but parts are not cheap for the 80s I know I just built one
the 60 will not work the cheap alt would be to get a th400 for around 300 and bolt it up or get a crank from a 2002 up and swap it out
Transmission: 4L80E/4L80E
Okay.
Using my Super Secret Spy Decoder Ring (thank you, Cracker Jacks), I think when you say:
You mean:
"You need a block that is '02-up. They used a spacer to bolt to the 4L80E's. The '99 to '02 just bolted up to 4L80E's."
It is true about the '02-up and spacers. My 6.0/4L80E had just such a spacer (and longer bolts).
But, you don't need the '02-up "block". It's the crank that is different.
And, as I already stated, there is a way to use an LS1 4L60E with an early 6.0 crank.
Engine: ls1
Transmission: 4l60e
So with all your information you all provided i think my best options is to get my ls 1 crank and shove It my 6.0...!!!
Thanks to lunati397 & five7kid for all your help...!!!!!
If you're pulling the 6.0 apart anyway, that's a good option.
Quick addition, but your years are off slightly
The longer crank was only used from 99-00 on iron head'ed 6.0's. If its got alum heads, its the short crank version
Iron blocks did not change enough to mention for all the GEN III years for each displacement. I.E. a 99 6.0 block is the same as an 05 6.0 block
