9c1 lt1 '86 Camaro parts question!
Old 03-11-2013, 10:06 PM
Ant1141's Avatar
I have a caprice lt1 that I'm swapping into my 86 5 speed I just recently bought the intake and aluminum heads from a Camaro lt1 and the PCM as well. The caprice lt1 came from a 9c1 cop car I also have that PCM as well. I was wondering should I exchange the intake manifold and the aluminum heads to the 9c1 lt? Or would it b wiser not to? Also should I exchange the PCM? I no the caprice PCM has been tuned I.e no limiter and so on, I was told the Camaro PCM has a stage 2 chip? Idk what else though maybe programmed as well. And I was also told the aluminum heads are ready for rockers? If that makes a diff. Please tell me your thoughts/experiences
Last edited by Ant1141; 03-11-2013 at 11:31 PM. Reason: HEADS Not headers stupid mistake sorry bout that
Old 03-11-2013, 11:12 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Aluminum Camaro headers? Do you mean aluminum Camaro heads?
Old 03-11-2013, 11:30 PM
Ant1141's Avatar
Re: 9c1 lt1 '86 Camaro parts question!
Yes sir my bad bout that
Old 03-12-2013, 04:46 AM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
I would do the camaro heads for the weight, won't be a whole lot put a cam in it that was one difference in the caprice- camaro hp ratings.
If the camaro PCM has a chip it is for a 93 and can only be used on a 93 motor.
midge54
01-29-2017 07:00 PM
redmaroz
08-16-2015 11:40 PM
Fronzizzle
08-09-2015 01:15 PM
1992 Trans Am
08-08-2015 08:16 PM
1nastygta
08-08-2015 07:38 PM
Quick Reply: 9c1 lt1 '86 Camaro parts question!
