88 camaro to impala ss lt1 swap
Old Mar 13, 2013 | 06:28 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
Axle/Gears: Ford 9in w/ Strange 3.70s
hi guys, getting kind of frustrated with my motor swap I'm thinking now that the guy i bought the motor and tranny from didnt give me all the right stuff. i have the motor in the car and wired up enough where the motor will turn over and crank and crank and crank but wont start. my understanding was that it would not work because i am using the factory key to the camaro that does not have a chip. so my questions are is there only one engine management unit or are there several because i still have a few plugs open. also i have found a couple different ways to get around the chip issue and i should have that solved by next week. i just need to know if im missing control units or not. ive done my research online and ive found three separate "control units" that are said to fit the car but, as i said, i only have the ecu that takes four color coded plugs and is grey in color. thanks for all your help. i need to get this figured out so i can pull the motor back out and paint the car.
Old Mar 13, 2013 | 06:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 88 camaro to impala ss lt1 swap
Have you used a noid light to test the injector pulse ? Sounds like you need to send a 50hz signal to the ecm or have the vats flashed out of the programing.
Old Mar 13, 2013 | 06:46 PM
Engine: Lb9
Transmission: M20
http://www.ebay.com/itm/GM-VATS-or-P...c6e343&vxp=mtr
Old Mar 13, 2013 | 08:10 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
i have a place that may or may not be able to flash it out of the edu but couldn't it be the same thing if i bought that key bypass?
thanks again
Old Mar 13, 2013 | 08:12 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
i havent tested the injector pulse can you elaborate a little more on how to do that. i have never done anything like that
Old Mar 13, 2013 | 08:14 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
also im told that i have to have it flashed if i dont have the bcm. is this true.
thanks so much for all your help i am glad i can finally get moving on this. along with the rest of the full restoration it has been a long time coming
Old Mar 13, 2013 | 08:16 PM
Engine: Lb9
Transmission: M20
You could contact PCM for less to have them reprogram out the vats or buy the modulator I put in the link above. A noid light is a light that is put place of one of the injectors when you crank the engine if the lingt blinks the ecm is commanding the injector to fire. The vats system if not working if the ecm does not see the correct hz signal it will not pulse the injectors.
Old Mar 13, 2013 | 08:31 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
sorry if i sound stupid but what is pcm
Old Mar 13, 2013 | 08:50 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
nevermind sorry
Old Mar 13, 2013 | 08:51 PM
Engine: Lb9
Transmission: M20
Power control module
Old Mar 14, 2013 | 05:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Powertrain Control Module
The other "CM"'s:
Engine
Transmission
May be others.
Old Mar 25, 2013 | 08:48 PM
legend71's Avatar
Car: 97 SLP SS, 91 RS, 91 GTA, 92 JY FF
Engine: LT1, VRE 383 LT1, L98, LB9
Transmission: 4L60E, Astro T-5, A4, A4
Axle/Gears: 3.42, 3.70 9Bolt, 3.23, 2.73
I had the same issue with my swap, the bypass module didnt do anything but flash little lights. Had the PCM reflashed and started right up
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
